Best gear cable?
[Closed] Best gear cable?
[#4636636]
Hi all,
New frame has internal cabling, so want to get decent cables I can so I don't have to go through the hassle of replacing them too often.
Running 1x10 so just need rear one. Runs a full outer. Looking for inner and outer of course.
Any recommendations?
Worth getting those with an inner plastic tubing (Flying Snakes?)?
Ta, Duane.
Posted : 09/12/2012 8:22 pm
Shimano SP41 outer and Fibrax teflon coated inners.
Posted : 09/12/2012 8:23 pm
When the Teflon coating wears off they're no good, no?
Posted : 09/12/2012 8:28 pm
Another vote for sp41 outer, not too fussy with my inners but outers need to be good quality.
Posted : 09/12/2012 8:29 pm
Any stainless steel inner is better than galvanized. Last much longer and a nice shift.
Posted : 09/12/2012 8:33 pm
SP41 plus any old shite for inners as it's full-length
I always put extra grease - thin stuff like M-Prep fork grease - in the outer too
Posted : 09/12/2012 8:34 pm
Duane... - Member
No, I've found them to still be good, but it takes a long time to wear off IME. They're a standard stainless steel cable underneath afterall.
Posted : 09/12/2012 8:35 pm
Right, sounds pretty promising for the SP41, cheers. And a SS inner.
Just out of interest is it possible to buy sp41 by the meter, that [i]actually[/i] has "shimano sp41" printed on it?
Posted : 09/12/2012 8:38 pm
teflon coated and SP41, anything else is wasting money
Posted : 09/12/2012 8:42 pm
Make sure you get Shimano PTFE cables, they are much smoother than say clarks.
Posted : 09/12/2012 9:15 pm
