Best DX type light ...
[Closed] Best DX type light from within the UK?
[#4413090]
Hi all,
So I'm doing Relentless 24 next weekend as a pair, and kind of don't have any lights..
I would like a headtorch (not too bothered about bar mounted as long as head is bright enough). Adjustable brightness would be good (brighter for descents of course)
Any recommendations, considering I need it by Friday latest.
Something like this (mod to mount to Giro Hex)?
http://www.ebay.co.uk/itm/Inton-XM-L-T6-Head-Lamp-1000-lumen-rated-led-/300780925585?pt=UK_SportsLeisure_Camping_LightsLanternsTorches&hash=item4607f0b291&_uhb=1#ht_2357wt_1139
Or this, plus a load of zipties?
http://www.ebay.co.uk/itm/Yezl-Q2-100m-Diving-Torch-CreeXM-L-T6-1000-lumen-rated-LED-4-brightness-levels-/300777077691?pt=UK_SportsLeisure_Camping_LightsLanternsTorches&hash=item4607b5fbbb&_uhb=1#ht_3978wt_1271
I know that the run time won't be too great, but happy to get a few spare batteries, keep charging them up and rotating them.
Any recommendations would be great.
Ta, Duane.
Posted : 29/09/2012 11:52 pm
I've just bought the Exposure Diablo and its great. Helmet mounted with loads of different settings. I've been using the 3rd setting which gives a medium brightness burn time of 6hrs and can easily be switched to a brighter setting for descents. You can also buy a piggy back battery pack which clips onto the light but don't know how much more burn time this will give.
Posted : 30/09/2012 12:09 am
Sorry, that's well out of my budget! Looking to spend under £50 ideally (I have a charger for DX type batteries), but could stretch to £60ish.
Posted : 30/09/2012 12:11 am
Item no 110940880284
1200 lumens, £32.90. Pretty impressed with it considering the price!
Posted : 30/09/2012 12:25 am
Thanks, sounds good.
Is there an easy way to mount it to the helmet?
And do you mount the battery on the frame? The good thing about getting a standard torch + zipties is that it's all together with the batteries (weight on head doesn't bother me too much..)
Posted : 30/09/2012 12:28 am
It comes with a headmount, which it just about stretchy enough to fit round a lid (though I use a proper helmet mount from another light set) I've managed to mount the battery to my lid, though I haven't used it in anger. Worst case you would put it in a bag/jersey pocket, as the cable is more than long enough.
Posted : 30/09/2012 12:35 am
OK, thanks.
Guess I'd have to bodge up a mount then, don't fancy using the elastic.
Can you get spare batteries? What kind of runtimes are you getting (and how to charge back up)?
Ta, Duane.
Posted : 30/09/2012 12:37 am
Dunno yet, only arrived t'other day, and only used it up and down the road! Give me a week and I'll report back!
Edit, not looked into spare batteries yet, pretty sure mtb batteries would be able to sort one though,
Posted : 30/09/2012 12:41 am
If you have a DX battery and charger you may be better with a standard head unit to pair with the battery pack, I'd expect you could get more for your money that way.
If you decide to go down the head unit only option try contacting smudge at mtbbatteries as he may have one within your budget and he normally is very quick with postage.
Posted : 30/09/2012 12:45 am
Thanks.
Sorry, what do you mean by a standard head unit? As tomhoward posted above? Can you get ones which accept standard DX batteries?
Posted : 30/09/2012 12:48 am
Any other recommendations?
Posted : 30/09/2012 9:27 am
I used one of these the other night along with my DX and I have to say I reckon you would get away with 2 of these the only thing is I do not know about runtime or longer term reliability but they only use one AA Battery but I got 24 duracells for a fiver off Ebay
http://www.ebay.co.uk/itm/160708522902?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
Posted : 30/09/2012 9:48 am
Try www.mtbbatteries.co.uk - great service and only a small premium for UK supplier.
Posted : 30/09/2012 9:57 am
What I was meaning is you could pick up something like [url= http://www.magicshinebikelights.co.uk/light-heads.php?ca=63 ]One of these[/url] and a helmet mount and use your own battery.
The link looks like it could be a uk shop but I have never used them. As I said smudge at MTBbatteries may be able to sort you out with something too if he has leftover bits from lights.
Posted : 30/09/2012 10:08 am
 Muke
I ordered a Chinese light with UK stock (arrived in a couple of days}
Then took the head strap mount
Cut a small slot in each side to remove straps and allow refitting if required
Threaded some velcro strip through mount
And thread strip through helmet vents to secure to helmet
Threaded cable through helmet out the back vent down to battery in backpac, has worked well so far 🙂
Posted : 30/09/2012 5:38 pm
juat got one of the above. Unimpressed with sealing on battery, it is now inside a section of old inner tube which has then been wrapped in duct tape, still fits in the frame mounting bag and should get it through winter!
Had planned to so something similar with the head mount, as Ive previously used a modified ancient Niterider bracket to mount ebay torches to my helmet.
Posted : 30/09/2012 6:51 pm
