Bent brake lever - ...
[Closed] Bent brake lever - Saint spares ?
[#2419180]
Ive slightly bent my brake lever, does anyone know where I can just buy the lever, not the whole thing. Its a SAINT M810. Ive looked on CRC and they only seem to stock the lever at £50.
Cheers.
Posted : 30/01/2011 6:40 pm
 Crag
I had the same problem with my Xt lever. Lbs got me a spare lever from madison - went to pick it up and was told it was £40, exactly the same rrp as the full lever assembly. Needless to say I didn't buy.
Posted : 30/01/2011 6:54 pm
Mmm, thats shite. Ive googled it and all I could see are complete sets.
Posted : 30/01/2011 6:55 pm
Part no. 8UL 9806, in stock at Madison, but as Crag has said, it's £40. If you've got a good relationship with your LBS then you may be able to wangle a bit of a discount.
Posted : 30/01/2011 7:12 pm
 Pook
Its aluminium, if I bend it back it will mostl likely snap.
I wonder if any after market manufactures make levers that fit ?
Posted : 30/01/2011 7:39 pm
Straitline make them but they aint cheap neither!
fwiw i bent mine back and its been fine for a long time
Posted : 30/01/2011 7:41 pm
Well the problem with trying to bend it back is if it does snap then Im stuffed. It works now, so Id rather try to get a spare before trying to bend it and end up snapping it. Its the front one, so that would be game over if i bust it.
Ray Mears is on telly, perhaps I should make one out of wood instead.
Posted : 30/01/2011 7:52 pm
You should get away with bending it back the once. i did the same on my old LX and it was good as new. Do it again and the metal will probably fatigue and then you'll be in trouble!
Posted : 30/01/2011 8:50 pm
 DeeW
I've got a spare lever assembly. New style saint 4pot. Had a leak in lever somewehere when on holiday so had to replace the whole lever assembly. Lever itself is fine and straight. £12 posted?
Posted : 30/01/2011 8:55 pm
YGM !
Posted : 31/01/2011 9:32 am
