...if the maxle rear end for a Five can be bought separately and if it can be fitted to a 2005 front end? I think the answers are yes and yes (and possibly why - creaking and I like the way the bolt through front end works so that's why), but has anyone done it / priced it / check it out?
Dunno but I'm running a 10mm bolt up rear wheel in my 2005 five
Replacement swingarm for a an 07 patriot was £320...TRADE!
Rorschach - ouch! add in a service for my shock and I might as well sell the frame and buy a new one.
jam bo - Interesting - 10mm fits the standard dropouts OK? Thought they were 9mm? And can I convert a Hope Pro II to 10mm (without resorting to machining bits specially)?
[Url= http://www.singletrackworld.com/forum/topic/hope-pro-2-135mm-qr-stiffening-up-options ]some options[/URL]
I seem to recall it's £500 to have a new a maxle swingarm fitted (and painted)to an existing frame.
fits fine, quite snug. it was a wheel I had from my SX trail.
runs central in the frame as wheel unlike the bulb/721 that i had in there before.
OK - next question
The bolt on option is presumably a cheap steel allen bolt into a slightly more expensive aluminium axle, but are any of the bolt through options steel or Ti (other than a bit of 10mm rod and an M10 tap and die set)? - I have a morbid fear of aluminium screw threads.
And thanks for the info so far by the way, I can see a decent way forwards here.
You can get a 10mm bolt thru and get a 10mm saint (or other axle) and pop a bolt on the end...i would imagine it would be heavier though.
I have the 10mm bolt up and i'm not worried about the alu threads...
