Bedding in brake pa...
[Closed] Bedding in brake pads - does it achieve anything?
[#5278854]
As per the thread title really. Does bedding in brake pads really do anything or would my time be better spent just getting on and riding?
Uberbike Race Matrix pads if it makes any difference...
Danny B
Posted : 25/06/2013 6:03 pm
yes it does.
several sudden stops from speed on dry tarmac will see you right, shouldnt take more than 5mins
I can start a ride descending a big hill, on the road, i accelerate and stop repeatedly all the way to the bottom, where i splash the hot rotors with a bit of water from the camelbak (just for the good hiss)
i feel (through the lever) the pads working better after a couple of good stops.
you might achieve the same just riding, but if that 'just riding' is through wet and gritty conditions you may not bed in the pads and wear out a set in short time.
Posted : 25/06/2013 6:22 pm
Yes follow the above procedure and you'll be fine.
Firstly bedding in conforms the pads to the disc surface.
Secondly it adds a little layer of pad material to the disc surface.
Thirdly it heats up the pad compound and hardens it up as well. Thus ensuring a long and happy life without too much wear.
Don't bed them in and they'll wear down quickly and lack power.
Posted : 25/06/2013 6:43 pm
People wonder why the peaks eats new pads when they put new ones in mid wet ride and they are gone by the end of the ride
Mike hall baked his in the oven prior to winning the puffer, only changed them once in comparison to 6+ times for competitors!
Posted : 25/06/2013 7:35 pm
 JAG
The bedding procedure does these things;
[technical lecture]
What actually happens is that the friction level between the pad and disc increases slightly (about 5-20%) and the variability in friction between stops decreases. This makes the brake respond more predictably and makes it easier to modulate and control.
[/technical lecture]
You should do 20-50 stops at a moderate rate of deceleration and not over heat them.
Good luck 😆
Posted : 25/06/2013 7:46 pm
I bedded in a front set the other day by braking up and down the road, then humiliated myself by stopping hard and nearly going OTB in front of the neighbours because the power had increased so much in just five minutes...
Posted : 25/06/2013 8:45 pm
I thought is was reasonably fit until i bed my new pads in last week. 20 stops at moderate speed and 10 stops at fast speed. Up and down a hill. I was absolutely stuffed by the end!!
Posted : 26/06/2013 2:12 am
never bothered bedding in pads in my life, and i manage to get a good 4-6 months of riding per set and i've never had to change a set of pads during week long alps trips either.
Posted : 26/06/2013 3:02 am
Likewise never bedded them in either and pads last months. Think about it braking moderately several times is what you'll do on an average ride anyway. Yes they improve after a few times of doing this but no need to out of your way to do it.
Posted : 26/06/2013 7:01 am
I never bother doing anything different tbh. Just go out and ride. I suppose given the time before steep stuff i do drag and test brake a number of times. Never had to change my pads last year in Alps - pila, la thuile, tignes les arcs etc.
Saying that i wouldnt go straight into dh on fresh pads if possible.
Posted : 26/06/2013 8:01 am
It's a waste of time. The first decent hill will bed them in anyway.
Posted : 26/06/2013 8:15 am
Unless it's wet and gritty, in which case they won't get hot enough to bed in properly and they'll just get worn away really fast.
Posted : 26/06/2013 8:25 am
I find it hard to believe that pads need some sort of heating process to harden up, especially baking in an oven. If that were the case then the manufacturers of the pads would do it as part of their process.
No doubt some conspiracy theorist will now pop up and argue "Why should they? Wearing down quickly will help them sell more pads." I'm pretty certain that pads which wear down quickly and don't stop too well would very quickly get an adverse rep and affect sales.
A slight increase in braking efficiency caused by bedding in to the disc I can believe but not some miraculous transformation of the pad material.
Posted : 26/06/2013 8:46 am
I only ever bed pads in if it's winter or wet/grimy riding. The rest of the time I just do it on a ride.
Posted : 26/06/2013 8:55 am
*Wistfully thinks back to the days of TJ's pad-bedding-in evangelism*
Posted : 26/06/2013 8:58 am
When perfectly mundane technology hits mountain bikes it (apparently) behaves completely different - especially brakes. In any petrol powered vehicle with new pads you just ride or drive with a little more care for a few miles.
But when you put brake pads in a mountain bike?? Oh no no! That is completely different! They must be heat cycled, no, baked, no, they must be used gently or they'll fall apart, or is it used hard or they'll fall apart, or..?
See also "you need a special tool to push brake pistons back in" and "brakes un-bleed when upside down (but don't re-bleed when the right way up)".
Posted : 26/06/2013 9:00 am
You had me until that bit. When did you last need to push the pistons in on your car (FWIW I use a screwdriver anyway) and when did you last store your car upside-down 😉
Posted : 26/06/2013 9:07 am
Never understood it myself. I've certainly seen no evidence for my own pads that not bedding in stops them lasting a long time. 6 months is normal on my bikes, even in the wet.
But if it makes you feel better, go for it. Don't forget to wear your cycling specific socks, only ride geared bikes to protect your knees and ride about with no brakes on your fixies because fixy braking is better than normal braking while you're at it. 😉
Posted : 26/06/2013 9:11 am
A waste of time if you dont clean your rotors first to remove the transfer layer created by old pads.
You need a nice long hill, warm the brakes up by "dragging" then do a handful of fast nearly stops.
Idea is to put an even layer on the rotor to match your pads, it will help stop judder and squeal.
Posted : 26/06/2013 9:16 am
>Does bedding in brake pads really do anything or would my time be better spent just getting on and riding?<
No and yes.
Just an old (stw) wives tale. Tried it once after reading pages and pages of guff spouted by TJ and others and it made not a whit of difference.
Can any of you pad bedder innerers point to documentary evidence from any of the brake or pad manufacturers? I've fitted many different manufacturers brakes and pads over the years and I have seen no such advice.
Posted : 26/06/2013 9:25 am
I definitely notice an increase in power after the bedding in period (same in a car too). I'd rather have predictable brakes than a sudden increase in power on a tricky descent. Therefore, I spend 5 mins bedding new brakes in. 🙂
Posted : 26/06/2013 9:30 am
When a car has new pads fitted they need to be bedded in just the same as bike ones.
The thing is car pads will bed in during the normal cycle of driving a car. A lot more heat and pressure is generated so it happens without changing your driving behavior.
With a bike, often the brakes don't get as hot, hence the specific recommendations to do it before you introduce mud and grit into the equation. Yes the chances are you will bed them in riding normally, but if you start off wet and gritty they will wear quicker until they are bedded in.
I dont get why people wouldn't bed them in. Its not like they are a safety critical component, oh wait....!
Posted : 26/06/2013 9:38 am
1) It wears the pad surface down to match the profile of the rotor, which is never completely flat even when new and definately not when old.
2) It transfers a microscopic layer of pad material to the disk, which increaces friction.
3) It hardens the surface of the pad so it doesn't wear out in 5 minutes.
I used to do it by riding down the road fom my house to the usual meeting point dragging the brakes alternately so they got really hot then cooled a few times. Haven't got big hills round here so ride round the car park/road pedaling hard against a dragged brake to achieve the same effect.
Posted : 26/06/2013 9:40 am
Avid brakes? 😉
Posted : 26/06/2013 9:44 am
 grum
I tend to do a few short sharp stops on tarmac if I remember. Seems to make a difference but hard to say how much.
Superstar do.
Posted : 26/06/2013 9:46 am
Drac - Moderator
Nearly. But if that first ride is in bad conditions, it doesn't always work out like that. And the first couple of stops are often weaker so it's a good idea to get that out of the way in controlled circumstances.
What made it really obvious to me was kevlar pads... With my old pads, they didn't perform well till they'd done a few stops, so i always just ran once down my road to get them up to speed- better doing it quickly on tarmac, than getting to the first corner of a trail and discovering they're still not 100%. So it was a non-issue.
But then I got kevlar ones, which make good power as soon as you fit them, and thought "no need to break these in". And they basically evaporated, one ride in the pentlands and I was down to backing material at the front and almost gone at the back. So I thought, bad pads, but I still had another 2 sets so I fitted those, bedded them in like I normally do even though I didn't think they need it, and lo- they lasted months.
Repeated this unscientific experiment at an enduro race last year- had to sling new pads into the back, didn't bother to bed them in, they were gone at the end of the day. The front set were already well used, but lasted the day out no bother.
Posted : 26/06/2013 9:47 am
Look at the speed he rides tho. He probably never uses the brakes.
Posted : 26/06/2013 10:01 am
I'm very unconvinced by anything involving ovens and brake pads.
1) ovens are generarly ful of oily crap
2) Brake pad manufacturing involves temperatures your oven can only dream about by an order of magnitude.
Posted : 26/06/2013 10:20 am
Bluff
Posted : 26/06/2013 10:28 am
OK 2 sets of Shimano XT brakes on 2 new bikes.....
1st set were bedded in to the letter of the law with around 15-20 stops each down a tarmac hill
2nd set weren't bedded in but rode from scratch but in the dry
1st set squeal 2nd set don't
My theory is if fitted when dry don't worry about it, if fitted when wet then a few brakes (5-10) down a hill before you hit the mud but that's it.
Also i now use sintered in the back and softer ones in front, all year round
Posted : 26/06/2013 10:35 am
Used to do it meticulously then one day I forgot and haven't bothered since
Posted : 26/06/2013 10:37 am
 dday
There is some truth in bedding in pads, however, given the new technology and materials used these days, is far less important. I suspect the difference in feel most experience during those initial stops is caused by the clearance of grease and other crap on the pad surface, and the pistons / pads getting nicely aligned.
I don't see shimano or avid proclaiming 20 to 50 stops before effective use on their documentation. I did maybe 3 or 4 strong pulls on my new XT pads, and they made it through winter, and still going strong.
thisisnotaspoon - Member
ovens work for rescuing contaminated pads.
Posted : 26/06/2013 10:38 am
Really? I've ridden in the wet and guess what no issues.
Posted : 26/06/2013 10:42 am
Drac - Moderator
I mind I put new pads on up in horrid conditions up in torridon once, they lasted about 2 hours, mind you the old pads didn't last very long either mind.
Posted : 26/06/2013 10:46 am
theblackmount - Member
Formula:
All new brakes, new brake pads and new discs have to bed in. This requires at least 50 applications of the brakes at a speed of 30 Km/h before the brakes reach the maximum performance. Make sure you are in a zone where there is no road traffic to bed the brakes in.
Shimano:
Avid:
Hope:
To achieve the maximum braking performance, the new pads will need bedding in. Please note that sintered pads take longer to bed in than organic pads. To bed in the pads, ride a short distance whilst alternatively gently applying the brake on and off without attempting to stop. This procedure will achieve good braking performance but will reach its full potential after a few rides
Posted : 26/06/2013 10:48 am
 dday
Cant be a genuine note from Shimnano, the english is too good..
Posted : 26/06/2013 10:59 am
of course using muc-off and an aerosol disc brake cleaner after each ride, plus a wipe over the frame with WD40, keeps everything nice too.
Never been a fan of cleaning agents on a bike except on the chain. Everything else is given a gentle hosing and a wipe down.
Theres certainly no need to be using disc brake cleaner after every ride whatsoever.
Posted : 26/06/2013 11:06 am
Bedding in to mould the pad surface to the rotor - I believe that, it's just logic, especially when your rotors are as old and grooved as mine. Sintered take longer.
Transfer of layer of pad material to the rotor - the links that come up on here previously are from motorsport websites, but on an mtb the moment the brakes get wet/muddy, this layer is going to be removed, so that isn't relevant.
Baking hot pads? They should be pretty damn hot when made, especially sintered. Maybe the cheaper ones aren't made very well.
Posted : 26/06/2013 11:25 am
Well I push pistons back in every time I change pads on anything, cos generally the news ones are thicker than the old. I don't store my van upside down, but my dirtbikes and mountain bikes have always spent a fair bit of time that way up just as a normal part of being ridden. 😀 And I think the manufacturer would expect and allow for that.
Posted : 26/06/2013 11:29 am
 Joe
Load of nonsense old wives tale STW rubbish. My brakes bed in after an hour on the trails.
Posted : 26/06/2013 11:33 am
50 applications of the brakes?! 😆
Who the hell has time for that before a ride? or at all?
Posted : 26/06/2013 11:54 am
Fair dues Northwind...
From your Hope link:
"This procedure will achieve good braking performance but will reach its full potential after a few rides"
Ergo you still need to do a couple of rides to complete the bedding in process.
So like many folk I've been unable to detect any real world difference (in either longevity or braking performance) between bedding them in first and simply bedding them in by riding the bike.
Posted : 26/06/2013 1:34 pm
