Because I'm no...
[Closed] Because I'm not rad to the max........
[#5224575]
I hoping to get away with running a 1 x 10 setup without a chain guide 😯 cue omgs and wtfs.
Any who it'll be on a hard tail I do have a clutch mech and it will not be blatted down hill.
Soooooo my question is........
Which chainring should I go for ? Cheaper the better preferably under £25-30
I know about the xx1 type things and the alternative but they are a little out of my price range ATM.
Cheers guys
Posted : 06/06/2013 10:36 pm
At least get a top guide. I guarantee that you'll drop the chain without an XX1 type ring or top guide. The top guide, clutch mech and normal chain ring combination works brilliantly with no extra drag and I've never dropped a chain. Just do it properly.
Posted : 06/06/2013 10:41 pm
Renthal seems highly regarded but went with a hope one in the end.
Posted : 06/06/2013 10:42 pm
Ive gone for a hope chainring on my 1x10 new build with clutch mech. Still in the middle of a build so cant comment on chain drops yet but i ride with guys that have clutch mech and no device and suffer no issues from dropping chains
Posted : 06/06/2013 10:43 pm
I'd go with an [url= http://www.on-one.co.uk/i/q/CROOSS/on_one_stainless_chainring ]on one stainless ring[/url] as it's cheaper and longer lasting~ with the money you save you could buy a [url= http://superstar.tibolts.co.uk/product_info.php?cPath=56&products_id=362 ]superstar top guide[/url]...
Posted : 06/06/2013 10:47 pm
I've been 1x10 for a while now. Replaced my outer ring with a bash guard and ditched the front mech. No chain drop at all. Totally secure, even over rough, rocky ground. I do have a Type 2 rear mech though, maybe that's the difference.
Posted : 06/06/2013 11:07 pm
wobbliscott - Member
But you've still got something to stop the chain dropping off the outside, unlike what the OP is intending.
Posted : 06/06/2013 11:09 pm
Running 1x10 on a hardtail with XT clutch mech, MRP chainring and no guide.
Ride around Thetford, so not exactly hammering any downhills, but I've not once dropped the chain.
I do have a Works Components XX1 style ring on order to give some extra security though.
Posted : 06/06/2013 11:13 pm
I got a Works one, just slightly above your £30 and seems better than the E13 it replaced for chain retaining... Haven't really tested it enough yet but 2 rides with no device and no drops.
Posted : 06/06/2013 11:19 pm
on one will last years
Because I [i][b]am[/b][/i] rad to the max, you're now dead to me
Luckily you have no idea who I am, which may ease the pain I guess
Posted : 06/06/2013 11:38 pm
Oh yah, meant to add- 1x10 with clutch and normal single ring just didn't work in the slightest for me, absolutely useless. Like, drop chain 6 times riding down falla brae at glentress useless, hardly the harshest test either so not really about radness.
1x10 with clutch and Works ring is working well so far, 1x10 with MRP 1X top guide worked very well before.
Posted : 06/06/2013 11:40 pm
Middleburn for the win.
Posted : 06/06/2013 11:43 pm
E-13 Guide rings are nice (last one did 4 years+)
Posted : 06/06/2013 11:44 pm
Cheers for the input guys anymore thoughts?
Come on scardypants show yourself lol
Posted : 12/06/2013 11:13 am
I run 1x10 on my XT cranks with no chain guide. It only drops off on the bumpiest descents or when I do little jumps. I might buy a guide eventually but its not bothering at the mo.
I only have an XT shadow rear mech with no clutch also, so I imagine your be fine.
Posted : 12/06/2013 11:18 am
 sv
Building a 1x10 at the minute and I have a Renthal chainring to go on, still cant decide on chain devices. Would a bash and say a Hope guide be sufficient? (Ordering a clutch mech)
Posted : 13/06/2013 9:02 am
Blackspire DH ring off CRC, they come in pretty colours and last years.
Posted : 13/06/2013 9:06 am
I'm going to be all non-STW and say an FSA DH ring, they're unramped and £16.40 at tweeks cycles
Posted : 13/06/2013 9:25 am
on one steel ring + superstar guide* working a treat for me.
(*it's the £17 one that's held on by the BB**)
(**which is a rubbish idea on it's own - i'm using an old DMR seat tube clamp to secure it at the top)
no clutch mech tho' - i guess i'm doomed.
Posted : 13/06/2013 9:47 am
Every time I read one of these threads and look at peoples wildly differing experiences I'm forced to conclude that while it sounds like we are all talking about the same type of riding, the variation in riding styles and terrain ridden is really so big as to render any recommendation other than "Try it and see how you get on" more or less useless. 🙂
Posted : 13/06/2013 10:12 am
WTF then what is the point?
Any how I have renthal & hope rings, renthal is nicer
Posted : 13/06/2013 10:20 am
 FOG
I have been looking at going 1x10 for a while mainly to avoid one more thing to adjust or go wrong but being an old geezer with little left in the legs I use the Granny ring, not a lot, but enough to think I would miss it. What gearing would be a reasonable compromise of climbing ability versus speed on more open bits or the road between trails?
Posted : 13/06/2013 10:28 am
Sram type 2 and no device here, OK so far, only one mid gnar chain loss in a couple of months, one when lifting over a gate, and one freewheeling over a rough wooden bridge. In short they hold the chain through tech, but there are other things with different types of motion that can drop the chain, I'm considering a simple top guide of some kind, a la the bionicon one.
Posted : 13/06/2013 10:36 am
FOG - Member
i'm a skinny weakling - i'm a twiddler, not a masher, and i've found 32ring + 11/34 cassette ok.
eventually, i'll get a 10speed 36tooth cassette, and i guess that'll be even more ok.
Posted : 13/06/2013 10:52 am
Running a Widgit chainring ( http://www.widgit.com.au/) at the moment with my XT drivetrain that includes a Shadow Plus and it seems to be working OK.
Although its a little above your budget you may be able to pick up a good 2nd bargain, it also means that you do not need to worry (in theory) about chain retention at the front.
Still early days with it but opted for a 30t ring up front (11-36t at back) and not found it too difficult to climb although I must stress I have only been out on a couple of solo runs so far.
Posted : 13/06/2013 11:18 am
Whilst waiting for my XX1 chainset I'm running a 10spd Zee rear short cage clutch mech and a Blackspire DH non ramped ring. I've had loads of chaindrops. I'm really hoping the XX1 will remedy this.
Posted : 13/06/2013 11:27 am
