Bearings for Truvat...
[Closed] Bearings for Truvativ Howitzer BB
[#1680951]
Any idea which bearings I will need for this bb? I have taken the old ones out and they only have 'truvativ sealed' stamped on the dust cover.
cheers
Sparx
Posted : 07/06/2010 2:47 pm
I think they are Truvativ only - which possible explains why they are crap.
Not sure if it's worth taking them to a bearing shop who can measure them and see if they are available from elsewhere.
Sorry to not have been of more use.
Posted : 07/06/2010 3:19 pm
Sparx: if you don't mind me asking, how did you get the bearings out? I've got one thats getting a bit sticky and would like to re-grease the bearings but I can't see an obvious way to get them out. I can remove the dust seal part easily enough.
Posted : 07/06/2010 3:27 pm
afrothunder: Once you have the cup out place it crank-side down, looking in you will see the lip of the bearing. Working around this lip with a suitable tool tap it out using a hammer. Finally place it in a vice and knock the whole thing out (or put it in a vice fromt the start).
If you have a socket set try and find one that will slot inside the cup and sit against the bearing lip and hit it out! this works much better than a flat head screw driver
sparx
Posted : 07/06/2010 8:24 pm
