Bearing specific Lo...
[Closed] Bearing specific Loctite?
 Bert
[#1386428]
Hi all,
My dad is going to be fitting new bearings in his Stumpjumper this weekend and has been told by the LBS that he should use Loctite on them. Is there anything in particular he should use or will regular Loctite do ?
Thanks in advance.
Posted : 05/03/2010 9:43 pm
Personally would only use loctite if the bearings were 'loose' in the linkages etc. If they are not 'loose' it will make them an absolute cow to remove the next time he want to replace them.
However if he does want to use it he needs Loctite 641 retaining compound. Should be easily available from a bearing supplier/engineering place.
Posted : 05/03/2010 10:34 pm
 Bert
Will Loctite 271 stud and bearing fit do?
Posted : 05/03/2010 11:03 pm
bit of retaining compound but agree with S Wobbler you shouldn't need it my baerings were simply pressed in on my stumpy adding retainig compound will make the job hell.
Posted : 05/03/2010 11:07 pm
 dale
not worked on a stumpjumper but when fitting bearings I go the other way, lightly grease the bearing housing to prevent them 'siezing' together
Posted : 05/03/2010 11:09 pm
Yeah 271 will do but, if I remember rightly, that stuff is designed for a more or less permanent fix and would be very difficult to get apart if you needed to.
Loctite should, IMO, be a last resort.
Posted : 06/03/2010 12:44 am
