BBB jockey wheels
[Closed] BBB jockey wheels
[#3488031]
Just one quick question: in the manual there is a little dripper bottle indicating something needs lubing. Grease or chain lube type stuff? It doesn't say which one. I'm assuming grease because surely a chain lube would just leak out. 😕
Ta
Posted : 22/12/2011 11:29 pm
usualy a grease port same as on dmr pedals
Posted : 22/12/2011 11:30 pm
Take seals off the bearings and lube them - there's not much in there when new and then grease behind the shields too before you fit.
Posted : 22/12/2011 11:33 pm
No grease port. It's in the assembly instructions. Oh well, I'm going for grease because common sense dictates that a chain lube will just leak out.
I've already taken the seals off and stuffed the bearings full of grease. There was barely any in there!
Posted : 22/12/2011 11:35 pm
All sorted and running sweet now I've got jockey wheels that have got all the bearings in and that have teeth that you can see! The old ones truely were a mess.
Posted : 23/12/2011 1:10 am
