BB92 Question
[Closed] BB92 Question
[#8010517]
Right.... I've got all the tools and am about to change my first press fit BB.
The new one arrived, and has a number of spacers but also a curious looking waffled piece of metal in the pack. Any idea what it's for?!
Seen here....
[url= http://www.commencal-store.co.uk/sram-bottom-bracket-press-fit-bb-92-c2x13851532 ]BB Waffly thingy[/url]
2nd question.... should I use grease or carbon paste? It's a carbon frame but assume there must be a metal shell within the frame?
Posted : 21/08/2016 3:35 pm
It's a wave washer - goes between the crank spider and BB face on some SRAM chainsets.
Posted : 21/08/2016 3:38 pm
ok thanks. I'll see if I have one on there then!
what purpose does it serve!?
Posted : 21/08/2016 3:39 pm
 mboy
The "waffly" thing is a wavy washer, which you need if you're running a SRAM GXP crank (I'm assuming you are, as a Shimano BB/crank setup doesn't need one). It's for taking up the slack when you torque up the non drive side arm, as there's no adjustment for preload like there is with Shimano.
You shouldn't need spacers on the BB as it's BB92 (they're included for use for BB89.5 or BB86 usually), but you may (assuming it's SRAM) need some of the clear plastic shims to assist with the wavy washer taking up space so the crank doesn't move side to side in the BB.
Hard to explain in words, could show you in seconds if you were here if that makes sense! 😕
Posted : 21/08/2016 3:40 pm
Thanks...I think I understand.
My other question was about whether to use grease or carbon paste when pushing the new BB in. Any tips?
Posted : 21/08/2016 3:48 pm
 gee
I've used carbon paste in mine.
Which cranks are you fitting?
Posted : 21/08/2016 4:04 pm
I've got a brand new superstar bb92 for sram cranks, ordered wrong one ages ago, if anyone wants it they can have it for postage.
Posted : 21/08/2016 4:10 pm
@nobeerinhefridge - I'll take it. Send me a PM
Gee- Sram gpx
Posted : 21/08/2016 6:30 pm
Normal grease, i would avoid anything gritty near my BB.
There is a hope video showing their install
Posted : 21/08/2016 8:56 pm
 gee
I mean carbon paste between the cups and frame. Grease in the bearings.
Posted : 22/08/2016 10:52 am
I've run into an issue.
Using my Park Tools BB extractor, I've managed to get the bearings out with no issues. But the cups are wedged firm. There is a little groove than I can just about get behind with the extractor tool, but with nowhere near enough pressure to smack it out.
Any ideas?
Posted : 23/08/2016 10:53 am
