BB91 2.5mm Spacer -...
[Closed] BB91 2.5mm Spacer - Which Side ?
[#3709359]
I am looking to fit some XT HTII cranks to a BB91 bottom bracket in a Specialized Carbon frame. I have the spacer and ring ( 9 and 10 in the pdf - see link below ) but does it matter if I put these on the drive or non drive side ?. Just wanted to know which was correct 🙂
Posted : 24/02/2012 12:41 am
normally I would fit it to the driveside as that is the side where you would want to run something like a BB mount chain device in it's place. Is your BB shell decinitely 73mm and thus only need one?
Posted : 24/02/2012 12:43 am
Andy, The shell on these carbon frames is around 80mm, only measured real quick but definitely larger than a 73mm. One spacer seems to do the trick, I guess go for drive side first and see how it goes. Cheers
Posted : 24/02/2012 12:48 am
ahh not paying attention. Press fit - yuck. Poor you!
No idea in that case but if they carry on the logic from the screw in type then it will be drive side if needed.
edit: normally the little multilingual instruction sheet you get with shimano stuff will say which side to put the spacer on normally. Failing that I'd wait to speak to specialized tomorrow.
Posted : 24/02/2012 12:50 am
Nah,poor YOU! Its like mocking someone that has just got ht2 on his bike when all you have is powerspline ;O)
Times move on.. read about why many bikes will go to press fit in the future. Its not just for ease of fitting in the factory.
Posted : 24/02/2012 1:01 am
