Forgive my ignorance, buuuut...
...would Avid BB7s (160mm for rotors) fit on the current model of the Genesis Croix de Fer?
I ask because I currently have a new pair on an old frame, but have a chance to get the latest Croix in a sale (before midnight tonight) in a more appropriate size than my current frame.
Now, the current model has the rear disc brake (also 160mm rotors) mounted 'inboard' as opposed to the more usual 'outboard', leading to my uncertainty regarding the compatability for the rear caliper unit to be fitted.
The answer is probably obvious, but a bit of caution and consideration can't go amiss.
Yes. They'll be fine.
If you pedal heel-in, Spyres have a bit more clearance, narrower caliper. But I do still prefer BB7s. I think.
Right you are then. Thanks lads.
Actually, what could I replace the big ring on the front with? The spec one is really quite ugly.
