BB7 Road vs. BB7 Mt...
[Closed] BB7 Road vs. BB7 Mtn calipers
[#7315858]
I'm assuming these aren't cross-compatible?
Have got some Mtn calipers would like to fit to a road bike (have got the correct levers)
Posted : 08/09/2015 9:05 am
it's only the pull ratio that differs so if you have the correct levers you'll be fine
Posted : 08/09/2015 9:07 am
There's a different cable pull between them (i.e. the arm is shorter/longer). One way round you end up with no power, the other way the levers pull to the bar but I can't remember which. So the road ones work with road levers or old cantilever brake levers, the mountain ones work with V-brake levers.
Posted : 08/09/2015 9:08 am
the mtn ones work with roadie levers -BUT need to adjust them often or they pull to the bar - got to be a pain in ass so i fitted road bb7s instead once i found a set on here !
Posted : 08/09/2015 9:30 am
The arms are actually the same length. The difference is that the ramps are steeper on the road version since the cable pull is less.
Posted : 08/09/2015 10:04 am
If you're short of cash and need to get the bike setup soon, I'm just about to sell a pair of BB5 road calipers with new pads for £25....(sorry to hijack post !)
Posted : 08/09/2015 10:45 am
