Bb7 post mount
[Closed] Bb7 post mount
[#6170440]
Trying to fit the bb7 on my chineses road frame and the front wheel wont go in , the disc hits the caliper .
Disc is 160 , forks are post mount .
i have the correct spacers .
Any ideas ?
Posted : 07/05/2014 7:27 am
in what way does the disc hit the caliper - does it go into the slot but catch at the top, or what ?
Posted : 07/05/2014 7:48 am
Yes, catches at the back. Wheel won't go .
Measure the post mount and it is 74mm which I think is correct.
Posted : 07/05/2014 8:01 am
Have you tried more spacers?
Posted : 07/05/2014 8:06 am
 pdw
Are you using the avid tri-align washers? If not, then I think you may need to in order to get the spacing right.
Posted : 07/05/2014 8:07 am
Using the spacers which came with the brakes.
Posted : 07/05/2014 8:11 am
Is it possible that the fork has been designed around a 140mm rotor?
Posted : 07/05/2014 8:21 am
But it is same at the rear , so I think you could be right .
Posted : 07/05/2014 8:36 am
Looking at the Sram website, I have ordered some long bolts and spacers.
Hopefully it will do the trick.
Posted : 07/05/2014 10:26 am
 kcal
I found that initially the BB7 would foul / with the rotor, but when came to align it all up, it sorted itself out. I think it fouled particularly when I used normal bolts and skipped the Avid bolt/washer combo.
Posted : 07/05/2014 11:03 am
