BB replacement - be...
[Closed] BB replacement - before I get the hammer out...
[#6115403]
I bought a Shimano XT/SLX BB to replace an FSA BB-7000, both of which nominally fit a 24mm crank diameter. It appears that the FSA V-Drive crank will not easily slide through the Shimano bearings (just in my hand, not installed yet). Should it slide in easily, am I ok to give it a wee tap with a rubber mallet, or are they actually incompatible despite numerous sources saying they are?
Posted : 14/04/2014 11:50 am
 D0NK
No idea whether those BBs are the same size but if you're sure yeah give em a tap. I normally have to tap my shimano cranks into shimano BBs, only gentle like.
Posted : 14/04/2014 12:06 pm
Thanks. I'll see if I can persuade it in...
Posted : 14/04/2014 1:08 pm
 IA
IME crank fitting is all about the soft face hammer.*
(certainly on my FSA cranks w/shimano BB.)
*or a rock and an octopus, of course.
Posted : 14/04/2014 1:15 pm
 Olly
Give it a tap. If you didn't have to it would rattle in use
Posted : 14/04/2014 1:22 pm
Not necessarily. My XT into a Chris King was tight but didn't require a tap, just careful alignment and a firm push.
Posted : 14/04/2014 1:30 pm
I had an FSA 24mm in a Shimano BB, no bother. But I sold the FSA BB that came with the cranks to someone else with a 24mm FSA that couldn't get it into a SHimano BB. Not sure what that's all about!
Posted : 14/04/2014 1:34 pm
or a bit of grease
Posted : 14/04/2014 1:57 pm
my old FSA cranks wouldn't fit in an XTR BB, new deore cranks slipped straight in
I think the FSA has an ever so slightly larger diameter spindle
Posted : 14/04/2014 2:10 pm
Much appreciated. The consensus still seems to be the rubber mallet!
Posted : 14/04/2014 2:42 pm
Plenty of grease + rubber mallet = job done. Thanks.
Posted : 14/04/2014 6:22 pm
