BB mounted blackspi...
[Closed] BB mounted blackspire stinger
[#4336781]
Will this rotate on the bb and go into the chain and chainring?
Posted : 06/09/2012 12:07 pm
mine has never moved since fitted.
Posted : 06/09/2012 12:08 pm
Not if you A) de-grease the contact area, and B ) tighten it up enough
Mine did to start with. I have now put a little bit of locktight on the drive side BB before assembly. Been fine since.
Posted : 06/09/2012 12:09 pm
Thats a good idea, glue and possibly give the surface a key.
Posted : 06/09/2012 12:36 pm
Mine only moves when I clobber it with a rock, unfortunately this happens surprisingly frequently and is mighty annoying as the chain then gets pinched on the stay.
Posted : 06/09/2012 1:41 pm
Mine's never moved, even when I've whacked it with a hammer!
Posted : 06/09/2012 1:57 pm
Depends how tight you do it up.
The downside of doing it up real tight, is that if you do eventually manage to move it, you can't easily move it back! I keep mine ever so slightly looser, it still doesn't move often but when it does I can get it back in place without needing a BB tool.
Posted : 06/09/2012 2:08 pm
some people see this is a benefit, as opposed to having the tabs (ie. part of your frame) damaged when an ISCG-mounted guide hits a rock...
Posted : 07/09/2012 10:35 am
 ffej
I assume this is only an issue when you're running without a bash guard.. I have an e13 bash and the stinger roller just touches, it shouldn't be able to move in that scenario.
Posted : 07/09/2012 10:40 am
