Would somebody care to explain the real world differences? It's been a few years since I owned Rockshox forks- early Revs in fact, and the damping wasn't a patch on Fox imo back then.
So, 2011 RS RLT Revs with moco for a touch over £300 or 2010 RS Rev Teams, with BB moco for £450 or so.
I can only see the damper as the difference between these two- is the blackbox worth the difference? Or am I better off buying the RLT's and getting them Pushed if need be?
Black box have a shimmed (speed sensitive ) rebound damper like push fit to rs forks, but also a shimmed compression circuit.
My understanding is that the compassion shim stack is only active after the flood gate has opened, which seems to be a bit of a strange setup.
In summary, it is broadly the same as getting a moco fork pushed
see here for a bettter explanation!:
http://forums.mtbr.com/showthread.php?t=538905&highlight=blackbox+vs+motion+control
http://www.bikerumor.com/2010/08/20/tech-article-how-rockshox-motion-control-works/
posted the other day covers all you need to know, personally I'd go for the Black Box damping, can also be retuned too.
Got the '10 Teams yesterday for around £380. Shop around. 8)
Thanks. So no feedback on the Race/ Standard Motion Control?
I've seen those at that price, but only qr - if you see 1 1/8 or taper, and maxle, post a link please.
