BB for RF Aeffect C...
[Closed] BB for RF Aeffect Cranks?
[#10033194]
I have some RF Aeffect Cranks - can I use a Shimano XT bottom bracket?  Or do I have to find an RF BB?  Thanks, help appreciated.
Posted : 11/06/2018 9:23 am
Sure can.... No problem at all.
Posted : 11/06/2018 9:26 am
24mm axle? if so, use any external. XTR BB93 BB's last a l o n g time.
Yes,  Aeffect cranks will work with an an XT bottom bracket. Just remember that if you already use the non-driveside crank axle spacers you will need to reuse them on the new bottom bracket.
Posted : 11/06/2018 9:29 am
Not a problem: I use a cheap Deore BB with one set and a Hope PF converter with another. I'd fit AEffect cranks to my Solaris as well but the current cranks are doing fine so no point.
Posted : 11/06/2018 10:00 am
I've got an issue with mine at the minute, in that I can't get rid of a small bit of play. Hope BB, new bearings, installed as per the instructions, with the correct amount of spacers. Don't 'think' it was there when I first installed them at the start of the year.
Going to add a spacer to the NDS (73mm shell) to see if it gets rid of it.
Posted : 11/06/2018 10:45 am
Thanks - really helpful.
Posted : 11/06/2018 10:53 am
