BB Facing a Scott a...
[Closed] BB Facing a Scott aluminium frame
[#5121808]
I bought a Scott CycloCross frame and forks 3 or 4 years ago, its an aluminium frame so not a current model as far as I can see.
The frame and forks came in the original box from the manufacturer, eg hadn't been opened or otherwise prepared by the shop I bought it from.
Lately the bike has been chewing through external bottom brackets, even in the dry. I think this is just bad luck with the shimano ultegra bearings, but it did make me wonder, Do Scott frames come prepared? Should I have had the bottom bracket shell faced when I bought it?
I've built up loads of aluminium frames and never felt the need to have this done before.
Ta
Posted : 02/05/2013 8:37 am
some do, some don't
It's not a bad idea to do it, especially as you are going through bearings. It's not a big job (if you have the tools 🙂 )
Posted : 02/05/2013 8:39 am
