BB Axle Length
[Closed] BB Axle Length
[#5004858]
What is your best guess at axle length for a BB 110 or 113
Shell is 68mm (I forgot to check axle)
It's Cannondale F6 Disc 5-6 years old 8 speed
I can whip it out tonight to have a look but I wanted to order one so it will arrive in time for me to fit it over Easter for daughters BF
Posted : 27/03/2013 11:58 am
110s are less common than 113s IME so just based on probability, I'd pick 113. Also, a 113 will will work even if it's meant to be 110 whereas the other way round doesn't always.
The key question is what chainset is it - that determines the axle length needed.
Posted : 27/03/2013 12:01 pm
Thanks clubber
it's a Shimano Hyperglide triple
I'm thinking risk a 113 or get both and send one back
Posted : 27/03/2013 1:01 pm
I don't recall Shimano doing chainsets needing a 110 so if it was me I'd be going for a 113.
EDIT - http://www.sjscycles.co.uk/shimano-alivio-fc-m410-7-8-spd-square-taper-triple-chainset-42-32-22t-prod15094/
This suggests a 110 axle so who knows 🙂
I'd still go for 113.
Posted : 27/03/2013 1:02 pm
What frame is it on? If its a big fat alloy one, then go for the 113. The front mech might not be able to swing back enough to drop it into the granny gear if not.
Posted : 27/03/2013 1:45 pm
Thanks all I've gone 113, it's only 1.5mm either side, what could possibley go wrong...
Posted : 27/03/2013 2:22 pm
...and the answer is it could be 122.5
who'd of thought
Oh and the left crank is ****ed from being ridden whilst it was loose
Posted : 27/03/2013 8:14 pm
Lots of shimano low end triples use 122.5
Posted : 27/03/2013 8:24 pm
