BB advice
[Closed] BB advice
[#1921923]
Got a racing bike frame and I was wondering what size bottom bracket I should put in it.
I measured it and this is the rough figures I came up with.
35x70
Posted : 23/08/2010 9:45 am
What chainset are you fitting? I assume the 70 measure is across the bottom bracket shell?
Posted : 23/08/2010 10:10 am
It's probbaly 68mm shell. The axle length depends on the chainset you're using, not the frame.
Posted : 23/08/2010 10:11 am
Was going to use a double ring chainset but I dont know which one.
It's for road riding.
I am open to advice from you guys.
I need something that will allow me to keep up with the other roadies in the group.
Posted : 23/08/2010 10:20 am
If it's road, it'll be 68mm
I'd suggest a compact double most likely - do you know what size cassette you have on the back. How fast are you - how fast are the other riders?
Posted : 23/08/2010 10:21 am
Don't you need to know what thread it is?
someone should know if you mention what frame it is
Posted : 23/08/2010 10:28 am
Yes, could be english or italian.
[i]If it's road, it'll be 68mm[/i]
Unless of course it is a 70mm Italian size obviously...
Posted : 23/08/2010 10:32 am
Yeah, ok, fair point...
Posted : 23/08/2010 10:34 am
I believe from chatting to lbs that it could be an Italian thread.
Also its up to me which chainset I want to use will then dictate the length of BB I will need.
And I may not be able to use a compact if I have a braze on front mech which I do.
I have a yellow alloy Fausto Coppi Gavia
Posted : 23/08/2010 2:39 pm
It does sound like an Italian BB - further backed up by the brand.
I'd suggest something like a Tiagra compact. You may have problems with the front mech if the braze on is unusally high but it's by no means certain as most do work just fine - best thing is just to try and see really though it will need adjusting to get the best from it.
Posted : 23/08/2010 2:45 pm
