Bastid Battery conn...
[Closed] Bastid Battery connectors??
[#4438641]
I've got a bit of a conundrum I now have 3 diffent Bastid type lights:
a P7 ~2 years old, an XML ~1 year old and one new XML...
The chrger for the 1 year old XML went pop a couple of weeks ago so I ordered the new XML (it was silly cheap on fleabay), they looked pretty similar and I figured the charger for the new one would work for the old one.
However, I was wrong, the New battary has a yet another slightly different connector, it won't fit in the old P7 chargers connector either so it's not 2.5 or 2.1mm so I have 3 lights and three different connectors I assume they are all all connectable via a suitable adaptor, but how may chuffing sizes are there and what size adaptors do I need now?
from readin up on it a bit I think I have 1x 5.5mm OD/2.5mm ID, 1x 5.5mm OD/2.1mm ID and 1x 6.5mm OD/?.?mm ID...
Does anyone do a good multi-diameter Coaxial-connector adaptor kit?
I can find individual 2.5 - 2.1 for instance on the web, but I've not found a [I]"cover all bases"[/I] kit yet and that's what I want to prevent me having this issue ever again... Anyone?
Posted : 08/10/2012 4:37 pm
