Basic brake questio...
[Closed] Basic brake question
[#778886]
I am building a bike, and got myself some wheels. M505's with centrelock hubs. I know there not the best wheels bit heavy but will do for now. My question is this.
I run Avid Juicy 3's which use a 6 bolt rotor. Am I best getting a centrelock to 6 bolt adapter, or buying new centrelock rotors?
Which centrelock rotors will work best?
Is there a recommended adapter? have looked but they do seem to be hard to find.
Posted : 12/08/2009 1:20 pm
get rotors, the cheapest center lock ones you can find in whatever size you need 160mm 180mm ?!?
Posted : 12/08/2009 1:22 pm
ps if you need a 200mm ive got a saint one unused you can have for £10 posted
Posted : 12/08/2009 1:23 pm
i would get centre lock you can pick them up for nothing on EBay as noone wants them I got 2 x 160 for 3 quid posted with lock nuts included.
Adapters will be about 10 -20 quid for a set iirc.
Posted : 12/08/2009 1:24 pm
I read somewhere, perhaps it was wrong info, but they said shimano discs are thinner so can cause problems. I would have thought as long as I get 180mm (my size) I should be fine.
Posted : 12/08/2009 1:33 pm
any 180 will be fine, dont believe the hype 🙂
Posted : 12/08/2009 1:38 pm
Thats good enough for me. Cheers 🙂
Posted : 12/08/2009 1:41 pm
have mix matched rotors +calipers avid /hope /shimano makes no difference whatever combo you use. Thin discs are worn ones
