Base coat for paint...
[Closed] Base coat for painting frame
[#10601574]
Prior to top coat going on some sort of heavy undercoat. Easy to rattle can spray, then wet and dry it smooth before final top coat/s
Can anyone recommend something. I suppose it doesnt need to be spray, just something i can rub down and remove blemishes in the metal that might show through, filler and the like.
Ta much
Posted : 28/04/2019 4:56 pm
 Bez
Spray Bike do a couple of primers/fillers for exactly this. (I’ve got one of them but haven’t used it yet.)
Posted : 28/04/2019 5:06 pm
without access to the fancy dan stuff to be sprayed through an hvlp gun then go for spray.bike
Posted : 30/04/2019 6:09 pm
Red oxide primer for a steel frame. Done it loads of times with BMX's.
Posted : 30/04/2019 6:33 pm
Just finished spraying an old frame with spray bike paint...very impressed with how easy it went on and the finish. I was recommended to use the primer with Zinc as i was spraying a raw frame. Highly recommended.
Posted : 30/04/2019 7:01 pm
