Bar Ends on a riser
[Closed] Bar Ends on a riser
 AB
[#306604]
I fear I know the answer to this one already ( 😳 ), but can I get away with bar ends on a low-rise riser bar for by short travel full susser?
Posted : 15/02/2009 10:03 am
Urrghhh....shudder.
But really, it's your ride fella....do what works for you.
Posted : 15/02/2009 10:05 am
If you want to why not. Its not a fashion parade
Posted : 15/02/2009 10:07 am
I use bar ends on any bar - I feel there's something missing if I don't have a choice of hand positions when climbing.
Posted : 15/02/2009 10:10 am
As ever TJ, you're wrong...
Actually, while I would advocate function over form in every other instance, this really just looks so awful that it should be banned. Just use a higher stem and a flat bar if you need bar ends.
Posted : 15/02/2009 10:11 am
With Tj on this one - how the .... would a high rise stem and flat bar negate the need for bar ends?
Posted : 15/02/2009 10:19 am
why not??? i wouldn't, but hey!
Posted : 15/02/2009 10:21 am
Whatever's comfy for you...just don't go down this line
Posted : 15/02/2009 10:24 am
bar ends on a flat bar are fine, hence the suggestion to use them with a higher stem/more spacers instead of a riser
but whats wrong with putting bar ends on a riser?
Posted : 15/02/2009 10:27 am
flat bars are USUALLY not as wide as risers
Posted : 15/02/2009 10:33 am
[i]bar ends on a flat bar are fine, hence the suggestion to use them with a higher stem/more spacers instead of a riser [/i]
A good option
[i]but whats wrong with putting bar ends on a riser? [/i]
Nothing
[i]flat bars are USUALLY not as wide as risers [/i]
Yep, Salsa are an exception
In summary, nothing wrong with putting barends on riser 5its your ride, its up to you), there are alternatives like a higher flat bar, but at the end of the day barends on risers look SHIT. Fact.
Posted : 15/02/2009 10:39 am
I kind of pity the people who say you shouldn't as it doesn't look right (cool) who cares, I'll wager these are the same people who I at spds and see biking as a lifestyle rather than something to merely enjoy, do whatever works for you, f@ck fashion!
Posted : 15/02/2009 10:55 am
 jack
I've used Ergon jobbies for a while, quite like having something to hook the thumb in when really going for it. Also nice to have some different positions for your hands. I don't think they look horrendous, but it's function over form for me everytime anyway.
Posted : 15/02/2009 11:16 am
I refer you to my mothers advice regarding the 'but that's what other people do' approach to life.
"If everybody else stuck a red hot poker up their arse would you be in the queue at the hospital ?"
Posted : 15/02/2009 11:20 am
"but it's function over form for me everytime anyway." - Jack - you were doing so well until you posted the picture of a singlespeed...
Posted : 15/02/2009 11:21 am
 jack
LOL
Posted : 15/02/2009 11:25 am
If the purpose of a bar end is to give an alternate hand position, how does the rise of the bar make any difference ??
I've always thought that the 'effect' of a riser bar can be effectively duplicated by the right combination of flat bar/stem/spacers.....
Posted : 15/02/2009 11:26 am
if it works for you then why not. Some people get so uptight about this, it's a bike ffs! Anyway it saves buying a higher stem and flat bars.
Posted : 15/02/2009 11:29 am
Always have done on my XC bikes no matter what people say. The headshock makes the front of the bike very light, and can be a real pain to keep on the ground when climbing so the bar ends are a must.
Even more important now the second bike is a singlespeed
Posted : 15/02/2009 11:39 am
 AB
Thanks guys, think I'll invest in a set and see how it goes.
Posted : 15/02/2009 11:59 am
Personally the can creek ones work best for me, knacked neck and nerves into right hand, so it works for me do it and do not worry what people say..........what do they know..................it is just a new niche 😀
Posted : 15/02/2009 1:47 pm
I thought I'd give some of those ergon's a try too.
Moooo!
Bit of an impulse buy but I've found that bar ends give the wrist a rest on longer rides.
Posted : 15/02/2009 2:09 pm
there's a queue at the hospital?
the wife's got a set of those ergon moo grips, I think they look great but then I also tend to push/carry my bike up the really horrible bits!
Posted : 15/02/2009 2:32 pm
Ergon again here on my bike in the snow. Aslong as you're not using L bend bar ends they look fine. I wouldn't be without my ergons now, they're a godsend on long rides where you need more than one position for your hands on the bars, particularly enduros...
Posted : 15/02/2009 3:08 pm
