Replaced XT caliper with SLX this morning. No seals either side of banjo connector. Is that normal?
Posted : 13/06/2020 10:16 am
No!
Posted : 13/06/2020 10:29 am
They came with my SLX callipers. Can you reuse the ones from the XT bolt?
Posted : 13/06/2020 10:31 am
Typically a copper washer or an o-ring.
Will need 2x o-rings to work.
Part no is 8SY 2800 If you don’t have any. Any shop can order them post free for you.
Posted : 13/06/2020 10:39 am
You can usually reuse the old ones. You probably shouldn't, but if it's o-rings and they're not damaged it'll usually be fine, and if it's copper washers you can either give them a wee bit of heat, or just squish them slightly more
Posted : 13/06/2020 5:26 pm
