Bafang ebikeists as...
[Closed] Bafang ebikeists assemble please
 benz
[#10573955]
As per previous posting, family decision to build up a Bafang converted bike to allow Mrs B to go out when B Jnr and friend are riding on horses - forest fire roads specifically.
A Dartmoor Hornet frame has been ordered - to allow me to strip components off a Transition Bandit which was built up but not used due to more XC focused biking nowadays.
Ultimately, reckon we will have a relatively high spec ebike for much less than buying off the shelf plus can swap onto other bikes if required.
I can get the option of 500w or 750w motors rather than the 'standard' 250w.
So...anyone on here use one of these motors? Any pros or cons?
Thanks in advance.
Posted : 09/04/2019 9:33 am
Don't you need vehicle registration and insurance for something above 250W?
Posted : 09/04/2019 9:40 am
i have had one on a cargo bike for 3 years now.
Cant remember if its a 500 or a 750 but its not a 250 for sure.
I kept it limited due to where i was using it (deeside way)
i had a 52v 20ah battery on it and it was unstoppable.
its needs a bit more input with the shopping or a passenger on now i have a 48v 17ah battery on it
MY motors and battery came from em3ev
IIRC your westhill or near by - im over in culter if you want to have a shot first.
- im actually away to strip it off the cargo bike and put together a regular comfortable ebike for the wife to use during the last stages of pregnancy.
Posted : 09/04/2019 9:42 am
 benz
TR, thanks. Yes, not far from Westhill.
It looks fairly easy to fit and set-up, or am I completely wrong with this assumption?
Appreciate the offer. I'll be in touch.
The bike won't be used on the public highway obviously.
Posted : 09/04/2019 9:49 am
easy to fit yes - basically replace the BB with the unit.
Running the cables neatly is an art.... i had it but then i stripped it down to lend it to someone while i was away and then just threw it back at the bike with cable ties 😀
you have a screen above the stem and set of buttons by the grip.
Knowing what i know now i probably wouldnt bother with the brake lever cut outs(so less wiring) for utility - as its pretty quick to cut out when you stop pedaling. Maybe different for MTB
And you have a wire to run to the rear wheel so it knows your moving.
FYI i would ditch the sprocket it comes with - a 44 or 42 and fit the spider conversion and a smaller ring - i run a 34t front ring with a 11-36 rear cassette on a sturmey archer 3 speed hub - but do remember i have a cargo bike set up that can weigh up a couple hundred KG so the range is good but the bafang motor does like a high cadence
Posted : 09/04/2019 9:57 am
How weatherproof are these things? Would one withstand muddy riding in the rain and being left outside the pub for a few hours?
Posted : 11/04/2019 10:57 am
i run full length guards such is the utility nature of the bike but its been through frequently grotty conditions commuting etc with not a complaint.
Also user serviable with (currently) spares availibility.
Posted : 11/04/2019 11:46 am
