Wondering if a small Seatpack (Revelate Shrew) will work on an AXS dropper ? Am thinking that the battery might mess with attaching to the rails.. ?
I run a weecog bag on the rails on mine with no issues so far if that helps.
James
Can't see why not, it'll just be a little lumpy around the battery, which you may want to protect as it may have a higher chance of knocking out.
cheers all, will give it a go. I am looking at an option of running an AXS dropper on a gravel bike with Rival eTap AXS 1x12 shifters, however I think I would need to get a blip box as both levers are used for rear mech shifting - one up, one down. That may push the cost a bit too high for me..
no, the reverb drops when both levers are clicked at same time.I have the exact setup above, no blips needed
Works a treat, my latest set up .
I like the Shrew.
any chance you guys could post some pictures of your setups?
honourablegeorgeFull Member
perfect, many thanks, am going to go with that setup, and great to hear :
aggsFree Member
Works a treat, my latest set up .I like the Shrew.
