Axle to crown measu...
[Closed] Axle to crown measurements
[#4858207]
If a rigid fork has an A - C measurement of 460mm what does that equate too in terms of travel if it was a suspension fork?
Thanks Nathan
Posted : 10/02/2013 10:17 pm
80mm travel
Posted : 10/02/2013 10:20 pm
Thanks Rob. What a-c would I need for 100mm equivelant?
Posted : 10/02/2013 10:22 pm
Sagged 120mm fork, roughly. Or not a lot of sag on a 100mm. 100mm forks tend to be 470-480mm extended, 490-500mm for 120mm. 440-450 for a rigid to replace a 100mm fork.
Posted : 10/02/2013 10:23 pm
So my Corratec Superbow frame is designed around a 100mm suspension fork but the rigids I'm looking at are 460 a - c. Do you think I'll be ok with them?
Posted : 10/02/2013 10:28 pm
Yeah, may feel a tad slacker than the working height of a 100mm but no problem.
Posted : 10/02/2013 10:30 pm
Ok thanks for your help mate
Posted : 10/02/2013 10:32 pm
 cp
Are you talking 26er wheels or 29?
Posted : 10/02/2013 10:33 pm
Posted : 10/02/2013 10:45 pm
Ah.. what do they say about assumptions? ) add 30mm to static lengths then.
100mm 29er is ~505mm a-c, so 470mm's common / 460mm's a bit steeper for a rigid.
Posted : 10/02/2013 11:37 pm
Thanks once again. It seems the search goes on
Posted : 11/02/2013 12:00 am
80mm? eh?
for 26" wheels 440-445mm is generally regarded as a 100mm travel fork equivalent. 460mm would be more like a 120mm fork.
Posted : 11/02/2013 12:02 am
apologise for old thread....I'm about to buy a rigid fork for newly bought El Mariachi 29" frame. Salsa's saying both the Fargo V2 with a-c of 468mm, and Firestarter forks a-c 483mm are compatible. Could someone explain in real terms what the 15mm difference will make to the bike?
Posted : 06/02/2014 4:55 pm
In the same boat as 'seventyfive' - I cant see any difference between the forks other than the difference in a-c. It would result in a head angle slacker by 0.7 roughly.. My guidlines would be el mariachi mtb - firestarter el mariachi touring machine - fargo fork
Posted : 17/02/2014 1:02 pm
seventyfive - Member
i degree of head angle = 17mm
Posted : 17/02/2014 1:04 pm
