axle size
[Closed] axle size
[#4058921]
If i convert QR to 12mm axle will it fit a standard QR frame?
Posted : 11/06/2012 10:57 pm
No, you can do a 10mm axle conversion on standard QR rear drop outs.
Posted : 11/06/2012 11:13 pm
Yes, as long as you convert it back to qr before fitting it.
Posted : 11/06/2012 11:17 pm
Ok will the hub require new end caps for 10mm?
Posted : 11/06/2012 11:18 pm
Yes and hub axle or you can drill them out if its hope hub.
Posted : 11/06/2012 11:20 pm
I was thinking about this one.
Do you reckon you can drill a qr pro2 axel to take a 10mm qr.
Posted : 11/06/2012 11:26 pm
Yes you can. Done it to front and rear. You can do the end caps too. Its easy with a pillar drill. You can do it in the vice with a hand drill but I wouldn't recommend it. The QR axle has a small reducer in the center. Most of the axle already has a 10mm id. Ive also done one to 12mm. Much trickier to center the axle not having a lathe but as a trial and error experiment, it is still in the hub and on my big bike now.
Posted : 12/06/2012 9:52 am
Cheers TheSwede.
I,ve got a lathe so i,ll stick it in that and drill it out. 🙂
Posted : 13/06/2012 5:23 pm
