Avid Road Discs wit...
[Closed] Avid Road Discs with v levers
[#1533719]
trying to recycle as much existing kit for a new build - I have the road version of BB7s plus some Avid SD Sl v levers.
I know in theory it's not a compatible combination but before puttihg together trying to work out what braking will be like.
I'm not an engineer - so my understanding is that the discs are designed to work with much less cable pull than the levers offer - doesn't that just mean that the brakes will be full on at a much earlier point in lever travel than if the same levers were used with the MTB version of the discs - and is that necessarily a bad thing(and why)?
Ta
Posted : 22/04/2010 1:39 pm
leverage is higher so you won't be able to brake as hard or mudulate as well, but it should still work, dunno how well.
Posted : 22/04/2010 1:53 pm
see if you can scrounge some canti brake levers. They'll work just fine with them. (same pull as road levers)
Posted : 22/04/2010 2:02 pm
Good idea. May have something old school going spare myself. email in profile.
Posted : 22/04/2010 2:04 pm
I did the same with mine, and actually I prefered it to some old mtb BB7s I had. It's difficult to say if you'll get on with it, but I found that it engaged quicker and after a couple of days I adapted to the modulation of them anyway.
Posted : 22/04/2010 2:06 pm
