Avid Matchmakers, w...
[Closed] Avid Matchmakers, why do they use a helicoil?
[#5367092]
Hi chaps,
Why would Avid use a helicoil in there brake mounts? I *somehow* pulled the helicoil out of one of my matchmakers - which I guess would assume putting too much torque through the mount, which seems crazy as I only do my mounts up so they just stop moving - so probably only around 4nm.
Anyone know what I can do to fix it? I've never used a helicoil before...
Here's a photo:
Ricks
Posted : 26/07/2013 9:48 am
Helicoil/thread insert ought to be stronger than bare aluminium- looks like Avid are trying to introduce a bit of gorilla-proofing, but it doesn't always work out.
Posted : 26/07/2013 10:15 am
Run a tap through it and put a bigger bolt in would be the easiest and cheapest option
Posted : 26/07/2013 10:17 am
Lol. That does make sense, as the clamps are a PITA to line up - so I can see how people could strip the threads or damage bolts.
Maybe I need to buy a helicoil insert tool...
Posted : 26/07/2013 10:18 am
Edric... thats one of the options I was thinking of. The threads just need chasing I think, so I'm in two minds about doing that and just using a bigger bolt (I have Avid bolts which would fit)
Posted : 26/07/2013 10:19 am
