I've got elixir 3's and noticed the front brake lever is bouncing up and down when off roading.
It's not much movement, just seems to be going past the "click" that moves it forward, and the brakings fine so just wondered if anyone else has had this issue ?
Thanks
Posted : 08/05/2013 6:49 pm
Hummm... Just had a play with my Elixir 5's There does seem to be some up/down movement but they don't go past the point of the click.
However if I put both levers past the click, the rear has a lot of play and feels quite floppy but the front has some tension behind it.
I really do need to bleed the rear though, it's not far from the handlebar. I wonder if you need to bleed the front?
Maybe not much help!
Posted : 08/05/2013 6:59 pm
