Having a bit of a nightmare with my Juicy Carbons. Have blead them many times, and they've been fine, but not this time...
Problems are as follows:
Brake lever doesn't want to pull back to the bar, with pad spacer in the caliper. Seems to be too much presure in the system, and ends up with brake fluid spraying out from tubing at the caliper syringe.
After bleeding caliper, and releasing lever from bar, it takes a lot of force to push brake fluid up to lever, which then pours out from around lever resevouir.
All steps followed as per Avid instructions, and clamps on syringe opened/closed as appropriate!
Any ideas will be greatly appreciated 🙂
Posted : 31/08/2011 8:53 pm
