After replacing the damaged pistons on a set of juicy 5's I've found that I will also need to replace the two little orings that go on the banjo bolt. I've looked online but can only find these as part of a caliper servcie kit costing £30. The LBS says they can only get them in as whole kits too.
Any ideas? I know you can get orings of all sorts from oring suppliers - anyone know what size, material and hardness these orings are?
due to an ebay picture size misinterpretaion and a leaking tap I have a set of a wide range of small (1-8 mm) mixed o rings.
Already fixed up somebody on here with one
If you can email (profile) me with inner, outer, diameter (of rubber) measurements I can pop some on the post.
and use the Advanced search option... 😉
Thanks for the replies. Email sent.
