Avid Elixir olive &...
[Closed] Avid Elixir olive & barb
[#3205679]
Any clues as to where I can get these items from, I've got 4 hoses that need shortening and need new ones.
Thanks
Posted : 03/10/2011 10:55 am
You may struggle to get them individually. The olives must be a standard size as they're the same as Maguras, the barbs aren't though.
The Avid bleed kit come with 4 sets of them. Avid bleed kits are like hens teeth though, for some bizarre and inexplicable reason
Posted : 03/10/2011 11:00 am
Ah bugger,
Posted : 03/10/2011 11:01 am
I can't see any reason you couldn't get away with re-using the barb though. Its only the olive that should need to be new. And I think they must be a standard size
Posted : 03/10/2011 11:03 am
MIght be worth calling the SRAM tech centre
http://sramtechcentre.co.uk/
They might at least give you the part number that you can then use to order through your LBS. They did that for the Elixir lever internals that I needed a while back.
Posted : 03/10/2011 11:06 am
I reused the barbs when I did my Elixirs. I think I used some Juicy compression olives i had spare which worked fine. You can get the barbs and olives on CRC.
Posted : 03/10/2011 11:21 am
Bleed kits also available on CRC. Though I think you can get some much cheaper non-Avid alternatives from ebay.
Edit: They say Juicy but that's what I've got and it works just fine with my elixirs.
Posted : 03/10/2011 11:22 am
Sorted from Bike Chase, winner!!
Posted : 03/10/2011 11:36 am
