Im looking to replace a Elixer 5 hose as its too short.
will these clarks kits fit elixir ?
could i use the clarks and modify in some way?the help
thanks for the help
DeerTrackDoctor
this one thanks
http://www.chainreactioncycles.com/Models.aspx?ModelID=52554
Juicy fittings are different from Elixirs, couldn't even find anything to work in our Goodridge fittings kit(found parts that fitted, but not well as they weep under pressure).
I gave up trying to change the lines on my Elixirs and sold the brakes tbh :O(
Jones bars are ace but they don't half need a long run of hose.
thanks so im a snookered withe short rear hose e to
i may have to sell it as a longhosed front! hanks DTD
i was hoping for somesort of fix
anyone else offer a solution please
thanks DTD
((A15022B) Avid Elixir Hydraulic Line Kit 2000mm ) - try your LBS and order via Fishers?
thank you sir !
