Avid brakes rubbing
[Closed] Avid brakes rubbing
[#3541262]
Anyone got any suggestions on how to stop my brakes rubbing? I've took my juicy 3's off my old frame (i/s bracket?) and put them on my new frame (post mount/no bracket?). I've tried to centre them by loosening bolts and pulling lever and re-tightening but can't lose the rubbing/drag. Any suggestions?
Posted : 08/01/2012 8:43 pm
I do the loosen then squeeze the brake thing to get them in the ball park. Then I spin the wheel in the direction of travel, adjust them by hand and tighten bit by bit as the wheel spins. Quick and easy, just mind your knuckles.
Posted : 08/01/2012 8:54 pm
Thanks 'weird number'. I'll give it a try.
Posted : 08/01/2012 8:58 pm
Agreed! I've chopped the end of my index finger off by getting it caught in a spinning rotor. It bloody hurt to say the least!
Posted : 08/01/2012 8:59 pm
Nasty stuff 'getonyourbike'. Think I'll just put up with a little bit of brake rub! Lol
Posted : 08/01/2012 11:41 pm
Make sure the piston isn't seized or corroded too.
Posted : 08/01/2012 11:51 pm
You don't have to spin your wheel fast enough to remove a finger! Just fast enough to listen for rub.
Posted : 09/01/2012 12:41 am
Worth checking the pistons, I always had problems with my Juicy 5s rubbing til I replaced the pistons and regreased with red rubber grease.
Posted : 09/01/2012 2:27 am
It's also worth checking your disk hasn't got a warp in it.
Easy enough to straighten.
Posted : 09/01/2012 10:12 am
Sometimes you just need to reset the pistons - so push them back with either the proper pad spacer tool or a plastic tyre lever or something.
The pistons should move out evenly, but often don't with Avid brakes (particularly Juicys in my experience).
Even if they don't move out evenly, resetting the pistons and starting the set-up from there can often get them running rub free for quite a while.
Posted : 09/01/2012 11:03 am
