AVID DISC Brakes.. ...
[Closed] AVID DISC Brakes.. Are they any good?
What will the weight difference be between a 160mm rotor and a 203mm rotor, as on one only have the 203s left, also as it is a rear one, does this mean that the size does not matter, will it definitely fit my trek ex 9.
Posted : 15/12/2011 7:00 pm
AFAIC most problems with Avids are user-inflicted... Though, they have all sorts of weird bugbears- hard to bleed well, horrible pad fitting on some, and the daft tri-align whose entire purpose is to add another dimension in which you can set the brakes up wrong.
None of that makes them bad, but I can't really see why anyone would ever buy them considering the strength of the competition. Especially with Formula and Shimano priced as they are now- you can spend more per end on Avid than it costs for a whole set of either of those, and get worse results.
Posted : 15/12/2011 7:04 pm
NO
Posted : 15/12/2011 7:17 pm
good tip on the xx pads two, i wasnt aware of that, nealy on the kits ive used that are non avid some are better than others but i they have all let a bit of air in and i think thats the biggest problem with bleeding them tbh. on the basis that you need the barbs id buy the kit, crc had a kit without 5.1 fluid, i think it worked about about 24 quid with the uk ten code.
Posted : 15/12/2011 7:20 pm
[quote="paulo6624"]nealy on the kits ive used that are non avid some are better than others but i they have all let a bit of air in and i think thats the biggest problem with bleeding them tbh. on the basis that you need the barbs id buy the kit, crc had a kit without 5.1 fluid, i think it worked about about 24 quid with the uk ten code.
I've bled the back brake tonight with no problems at all with the same non-avid kit so I must have been doing something wrong with the front one yesterday. End result is both levers are now firm so I'm happy with that. I might still get the proper Avid kit when I get round to shortening the lines. There's no denying it's a fiddly process but I can see the sense in it to get as much air out as possible but perhaps a different master cylinder and calliper design would make a normal bleed possible.
Posted : 16/12/2011 12:28 am
Formula use a pretty similiar bleed process to Avid, but for whatever reason it's much easier to get a good bleed. Or at least it is, now that I stopped assuming i know best and actually follow the instructions 😉
Posted : 16/12/2011 12:34 am
The piss poor effort I made of bleeding the brakes before I read the instructions properly and watch the video was laughable. Following the instruction does seem to have worked but I'll keep my powder dry on the celebrations until it's been a few weeks and any air in the system finds its way into the lines. I must admit bleeding my old motorbike brakes used to be a pain but nowhere near as messy and hard work as the Avid's.
Posted : 16/12/2011 10:05 am
 edd
If you want to have a go with Avid brakes for not much money I have a front 203mm and a rear 185mm Elixir 5 brake for sale, £20 posted. They will need bleeding but at that price they're great value.
[url= http://farm8.staticflickr.com/7162/6476764197_4bc2abd23c_z.jp g" target="_blank">http://farm8.staticflickr.com/7162/6476764197_4bc2abd23c_z.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/33251520@N07/6476764197/ ]P1010240m[/url] by [url= http://www.flickr.com/people/33251520@N07/ ]eddkh[/url], on Flickr
[url= http://farm8.staticflickr.com/7152/6476764023_69c4ca6470_z.jp g" target="_blank">http://farm8.staticflickr.com/7152/6476764023_69c4ca6470_z.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/33251520@N07/6476764023/ ]P1010232m[/url] by [url= http://www.flickr.com/people/33251520@N07/ ]eddkh[/url], on Flickr
E-mail if interested:
[url= http://farm5.staticflickr.com/4132/5059009807_30465204db.jp g" target="_blank">http://farm5.staticflickr.com/4132/5059009807_30465204db.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/33251520@N07/5059009807/ ]e-mail[/url] by [url= http://www.flickr.com/people/33251520@N07/ ]eddkh[/url], on Flickr
Posted : 16/12/2011 10:30 am
YGM
Posted : 16/12/2011 10:41 am
 edd
Just to be clear it's £20 per brake, not £20 for the pair.
Edd
Posted : 16/12/2011 10:47 am
OK & done
Posted : 16/12/2011 11:00 am
We've 2 sets of Juicy 3s at home, on both the stepkids' bikes. Because they've never been touched aside from pad changes they're absolutely fine.
Ham fisted maintenence will make brakes feel rubbish, it took me some practice before I learned to bleed my brakes properly but my Hopes feel absolutely fine. I've a set of Hayes Strokers on my xc bike, which are very powerful but they seem to share the same bleeding setup as Avid, so when they're due they'll be off to the LBS.
Posted : 16/12/2011 11:11 am
 edd
Sold to epicyclo. Thanks epicyclo!
Posted : 16/12/2011 11:21 am
Had juicy 3's which I find are plenty good enough for light xc. Also run Elixir R's which are powerful enough for me esp with organic pads it seems.
No issues, although after 3 years one of the elixIr's seemed to need more regular bleeding although i'm going to bite the bullet and start doing it myself. Hopefully its one of those jobs after a bit of practice you wonder what all the fuss was about.
Posted : 16/12/2011 12:05 pm
No. They aren't. HTH.
Posted : 16/12/2011 12:09 pm
damn,
i should check my own thread more reguarly, good have got some cheap brakes... :/
Posted : 16/12/2011 6:30 pm
this site up and down a lot eh? anyway
open any issue of Dirt magazine from the last year.. notice how all the bikes have Elixirs on them.
I suppose this is because they are 1) good and 2) cheap to OEMs.
unfortunately not such a good deal retail. i still buy them though, because of 1)
now glad i didn't buy the XXs thanks for the info (not taking sintered pads? useless in the UK!).
are Elixirs perfect? no. not enough pad clearance. even the tiniest imperfection on rotor = annoying noises. going through mud also a problem 'cos of this. and at least pre 2012, tend to not work after the bike is upside down, but a few pumps usually sorts them out.
sorry if i raised a dead thread.
Posted : 15/01/2012 11:29 pm
Ask Realman. I think he used to have a pair of avid disk brakes.
Posted : 15/01/2012 11:44 pm
Page 2 / 2
