Avid Bleed Kit
[Closed] Avid Bleed Kit
 Taff
[#4342803]
Quick and easy one, can any one give me the link to the good 'n' cheap bleed kits please?
Posted : 08/09/2012 3:53 pm
Ebay?
Posted : 08/09/2012 3:58 pm
Epic, on ebay
Posted : 08/09/2012 4:04 pm
[url= http://www.epicbleedsolutions.com/ ]epicbleedsolutions.com/[/url]
Posted : 08/09/2012 4:08 pm
 Taff
Thanks guys, ordered an Epic kit.
Question though, I though Dot fluid cause the expansion of the syringe rubbers?!
Posted : 08/09/2012 5:46 pm
I found the little o rings that epic use on their brass fittings swelled up and ended up too big. But they can be replaced easily, looking at Avids kit the use a better brass fitting with no o ring.
Posted : 08/09/2012 8:14 pm
Thanks for the referrals guys. Just to clarify, our kit uses the exact same o-rings as the official Avid kit. These o-rings are 100% compatible with DOT brake fluid and should not swell.
Please rinse your bleed kit with water and allow to dry thoroughly before its next use. This will maintain the lifespan of the kit significantly. If you leave the syringes with fluid in them post-bleed, corrosion of the rubber may take place.
Posted : 10/09/2012 10:42 pm
ebs - the tubes that screw in to the brake lever/caliper need a some kind of nut to grip on to.
In their current state they are frustrating to use specially once you factor in fluid, gloves and rubber tubing with nothing to grip on to.
The bottles need wider necks too as once you get about past the top quarter of the bottle it's nigh on impossible to fill the syringe without emptying out in to another container.
Other than that good work for doing at the price you do.
Posted : 10/09/2012 10:54 pm
 Taff
Was wondering what I was meant to do after use. Thanks for that. You've marked it as shipped so 'looking forward' to bleeding the Avids!!
Posted : 10/09/2012 11:16 pm
Patriotpro, our bleed adaptors do have a knurled section to grip onto to aid screwing and untightening. If you have one of our very old kits you may find them fiddly to use but we addressed this issue a long time ago.
As for the bottles we understand that they're a problem and we've already sourced a supplier of wide neck bottles. Once our current stock has been exhausted we will be making that change also. In the meantime if you tilt the bottle and draw fluid from the shoulder of the bottle. This negates the need to empty into another container.
Thanks you for the feedback. 🙂
Posted : 12/09/2012 9:11 am
 Taff
Bled my mates brakes tonight first time. Was surprised at how easy it was... not lpoking forward to doing my Elixirs though
Posted : 13/09/2012 10:25 pm
