I have a front Avid Juicy 3 currently connected to an IS mount Fox Talas 32 with a 160 rotor and standard Avid IS 160mm connector.
I want to fix this brake to some RS Pikes (also IS mount) and a 180mm rotor. I am really confused how to do this. It appears Avid only make a 185mm connector (not 180mm). Hope make a +20mm IS to IS adaptor which I guess would work?
Any other options? Is the Avid connection actually a Post sized fitting? Will any 180mm IS to Post wanger work?!
could get a avid 185 adaptor and then take out the avid semi circluar shims and use a few washers to space it that should loose the 2.5mm would need.
or just buy a 185 disc and adaptor 🙂
I use a Shimano 180 adaptor on CR mags. Works fine.
My Pikes have a shimano 180mm IS adapter with a 185mm rotor from a juciy 7
It looks like there is just another small washer in the stack to give the required clearance
I'm trying to swap my forks to some post mount fox vanillas and can I get a 185mm post-post.... no I bloody can't (well I can, its on order but its been a pain to sort out
Right, thanks for the replies.
So what we are saying is something like [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=17390 ]this[/url] will do the job if I remove the 160mm adaptor on it at the moment?
[url= http://www.google.co.uk/imgres?q=avid+juicy+mounting&um=1&hl=en&sa=N&rlz=1G1GGLQ_ENGB311&tbm=isch&tbnid=idd-1MRBbFleGM:&imgrefurl=http://forums.bicycletutor.com/thread-1594.html&docid=pXHf04RiytI1EM&w=448&h=306&ei=wEJRTsaALovItAaAtNjHAw&zoom=1&iact=hc&vpx=804&vpy=201&dur=1857&hovh=185&hovw=272&tx=67&ty=105&page=4&tbnh=119&tbnw=174&start=55&ndsp=18&ved=1t:429,r:16,s:55&biw=1263&bih=597 ]avid caliper with shims between caliper and mount[/url]don't forget some of the above replies are using a 185 rotor not the 180 so you will need to loose a bit of distance by removing the semi circular shims if you use a 180 mount in my opinion.
yes...and remember to put it on the right way up.. it says "up" on it..
I reckon your lbs will have a 180mm rather than wait for CRC
I use 180mm superstar rotors with avid code and juicy brakes, all i do is take out a washer from the mount, works a treat, been running this for a year with no probs
Thanks Chaps.
