Average weight for ...
[Closed] Average weight for trail/enduro bike?
[#5693643]
Weighed my Covert last night, and came out at 32.4lbs - is that on the heavy side for a trail/enduro rig?
It's running Fox 36's, reverb, and 721's so probably not the lightest build components. Just wondering what a good weight to aim for is?
Posted : 15/11/2013 11:06 am
People seem to aim for sub 30.
But coverts aren't the lightest frames around.
And 721 rims certainly aren't light.
So its not bad!
Posted : 15/11/2013 11:08 am
Go as light as you can, without compromising on strength.... it all depends on your budget.
 nuke
Sounds alright to me...my target would be around 30lb but still maintaining suitable wheels, tyres, forks, dropper etc so only by spending big money would I expect to hit the target
Posted : 15/11/2013 11:11 am
30lbs plus or minus 2lbs would be a very general average.
Posted : 15/11/2013 11:16 am
Not sure you can class it as a rig if its under 35lb
Posted : 15/11/2013 11:17 am
prezet - Member
it's fine, really.
if you want a lighter bike, buy one, then you'll have 2 bikes, and that's a win!
Posted : 15/11/2013 11:21 am
Blur LTc the missus has one at 27lb mine is 29 with some excess. Both would be happy on UK enduro.
Thought the missus did just have race face next cranks and an x0 cassette fitted.
I'm going to be moving to Flow Ex's in the new year, so hopefully that'll shed a bit more weight - after that I'd be spending lots of cash just for a few grammes here and there.
Posted : 15/11/2013 11:25 am
Go 1x10 too if you haven't already 🙂
Posted : 15/11/2013 11:28 am
Already there 😀
Posted : 15/11/2013 11:30 am
Theres no right answer to this, it depends on loads of compromises (and how much money you have)
But i reckon on accurate scales the average for most 160mm bikes would probably be around 30lb .
My Ibis Mojo HD weighs a bit more than 31 lb, which sounds pretty heavy for a carbon fibre bike, with carbon fibre handlebars and carbon fibre wheels, but it does have a dropper post, cane creek db air shock, coil sprung forks, 2.35 tyres, 2 x 10 gears.
It could very easily be down at 27-28lb I reckon, but I'd have to lose the dropper post, switch to a less capable rear shock, go to some less well performing air sprung forks, lighter tyres, 1 x 10 gears etc.
So we're back to the compromises.
Posted : 15/11/2013 11:39 am
My Norco is around that Weight. Want to get it to 30lbs. Wheel and tyre upgrades coming. New cassette etc...
Posted : 15/11/2013 11:43 am
Mine is 24 lbs - plenty of light weight but strong carbon stuff has helped I suppose, all gear I wouldn't have a moments hesitation with though.
*I should probably add that my 'Trail/Enduro' bike is a 140mm front / 125mm rear travel bike not a 160mm like most listed above so hence the lower weight.
Posted : 15/11/2013 11:45 am
Forks and wheels/ tyres make for the most obvious gains/ compromises. My Mojo HD with X Fusion slants, Arch Ex wheels, reverb and 2x10 XT weighs a smidge over 29 lb. It rides really well for its weight, and it'll weigh more when I swap my Flow wheels and some heftier tyres onto it if the Nics get shredded.
Posted : 15/11/2013 11:54 am
julians - Member
Plenty folks with much heavier builds than that claiming much lower weights.
Posted : 15/11/2013 11:58 am
My covert comes in at 31. 2x10 with a cheap cassette, slx f&r mechs but with X0 cranks. Pro2 hub with a flow up front and a spank spike on the back - 2.4 RQ up front and a baron out back. 36 floats, deore brakes, renthal fat bar plus a reverb, nothing really lightweight so you could get it down quite easy.
Posted : 15/11/2013 12:11 pm
Me! Always thought mine would weigh a ton
Posted : 15/11/2013 12:14 pm
My Stumpy Carbon FSR 29er comes in at one hairs breadth under 30 (29.9lbs), setup tubeless with fairly modest kit spec and a dropper post.
Reckon there'd be a couple of pounds to be trimmed with bling kit, but then when I ride it hrough the winter and smash it through the North Wales scenery on a regular basis I wonder why I'd want a £200 rear mech or £1000 wheels
Posted : 15/11/2013 12:23 pm
Large 2008 S-Works Enduro carbon - dropper post, 3x9, XT, EN521 rear, X-Fusion Vengeance. Bang on 30lbs on accurate luggage scales
Posted : 15/11/2013 12:33 pm
yep, I had noticed that. Always wondered why mine was much heavier than others. Maybe my scales are broken 😉
I guess we should take internet bike weights with a pinch of salt.
Posted : 15/11/2013 12:35 pm
My MojoHD comes in at 31.6 with flow ex, 1x10, reverb and 36 and thats a carbon frame
I am quite the fat bastard, but half of it is my jew fro and my boss's white sauce. So the average weight is probabaly 28 pounds give or take my bossmans juice. (on the bathroom scales).
Peace out homies.
Love in the hood.
#mountainbikesaregay
Posted : 15/11/2013 12:38 pm
 LoCo
21" 2011 Remedy, 29er front wheel, 27 (.5) rear (arch pro 2 evo) XT 2x10
pike 29er and DSP Racing dueler (ti spring) 28.8lbs
Posted : 15/11/2013 12:41 pm
Hmm, ok full spec:
Renthal fat bar lite
Renthal duo stem
Fox Float 36's
Fox Float CTD shock
Hope Pro 2's / 721's / 2.35 Hans Dampfs
Medium framed Covert
Reverb dropper
WTB devo saddle
SLX cranks
SLX brakes
SLX cassette
Zee mech
SRAM 1051 chain
Superstar nano pedals
SB66c, bit under 28lbs. XX1 saved a good chunk of weight, this is still pretty light for having Float 34's and a Reverb. Could save a bit by removing the Reverb and having Float 32's but would totally ruin the bike IMO.
Posted : 15/11/2013 1:02 pm
Full spec: Mojo HD in 140 flavour frame, with MRP guide
X Fusion Slant RP2
Fatt Funnboy 750s
SRAM contour foam grips
XT brakes,
Hope Pro2 Evo on Arch Ex
Nobby Nics tubeless
reverb, spoon
XT M785 2x10 drivetrain
[URL= http://img.photobucket.com/albums/v116/emilysdad/Mojo%20Build/036-1.jp g" target="_blank">http://img.photobucket.com/albums/v116/emilysdad/Mojo%20Build/036-1.jp g"/> [/IMG][/URL]
Posted : 15/11/2013 1:20 pm
@loco would you mind posting a photo of your bike?
Posted : 15/11/2013 1:36 pm
Specs...
Blur LTc
Option 1 (mine)
Fox 34 - perfect option not overkill like the 36 not xc like the 32
Hope Pro II/Mavic 719 -good tyre shape great tubeless tough as nails
X9/X0 drive train
KS LEv
Hope M4 Tech's
Thomson & Hope finishing gear
E-13 2x Guide
Comes in around 28-29 depending on exactly whats on
Option 2 (the missus bike)
Same frame
Fox 32 150 - perfect for the lighter rider 🙂
Same wheels
SLX brakes
Hope HS/BB
Reverb
Raceface Next Cranks (lighter than air) X9/X0 rest
There are still lighter race wheel options for both for a sensible price.
Posted : 15/11/2013 1:44 pm
 LoCo
Certainly, think the weight quoted above was with the revs (as seen in older picture below( van's a different colour too now)) on not the pikes so probably about 30lbs as running a steel spring too now as a test, can't weight it now as shock is off being shortened and tuned 😀
[url= http://farm4.staticflickr.com/3684/9464791186_6033aee17e.jp g" target="_blank">http://farm4.staticflickr.com/3684/9464791186_6033aee17e.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/55204994@N03/9464791186/ ]photo (2)[/url] by [url= http://www.flickr.com/people/55204994@N03/ ]Loco Tuning[/url], on Flickr
Posted : 15/11/2013 1:54 pm
My Five currently comes in at 29.3lbs with RS Revs, 1x10, Reverb and EN521/Hope wheels. Have just switched 2" Mud-X tyres for the winter and am running them tubeless but in the summer with tubed Conti 2.4" tyres, it was a hair over 30lbs.
Posted : 15/11/2013 1:58 pm
I dont understand why trail bikes are so heavy and we accept it. If manufactures can make full DH bikes that weigh less than 35lb why are trail bikes not significantly lighter?
Posted : 15/11/2013 2:24 pm
depends what you want
just look at wheels
719s or arch ex will help keep the weight down but flows or 721s will be a lot tougher
depends on what your definition of enduro is and where you ride etc
and as for DH bikes well they only usually have 1x setups and tiny seatposts with minimal saddles compared to 400mm of hydraulic dropper posts etc
and Im not sure that I have the madskillz to float over a rock garden on a 35lb dh bike without the potential for trashing a very expensive piece of kit!
Posted : 15/11/2013 2:32 pm
Perhaps if you spend the same on your trail bike as the cost of 35lb works DH rig?
My large Pitch has nothing especially light and plenty of portly parts - Rever, dual ply tyres, mid-range group, cheap SPD trail pedals, cro-mo saddle, big discs and Lyriks. Not checked it but I'd guess its in the region of 32lbs.
It rides great. If I wanted light weight I'd rather buy another bike to use to speedier sportier rides - whic stangely was exactly what I'd done about 3 weeks before all my bikes got pinched 😳
Posted : 15/11/2013 2:35 pm
In current form, mine comes in at 30.5lbs - at one point early season, had it down at 29.5 mainly to see how low we could get it, but that was with silly light and fragile tyres.
[img] ?w=640&h=480[/img]
Build spec in the photo:
Bionicon Alva 180 Air (small)
SRAM X0 1x10 drivetrain with Absolute Black direct mount chainring
Specialized Command Post
Superstar Racer carbon saddle
Superstar Tesla/Sentinel wheelset
Onza Ibex 2.25/2.40 tyres
DMR Vault pedals
Just swapped the brakes out for Zee from X0 after smoking them in Finale, so a slight weight gain there that will probably bring it closer to 31lbs, as well as a new chain device with taco after bending the unprotected chainring on a rock.
I'd say from what I saw this year in Europe, 30-31lbs is about average, you can probably go lighter in the UK but out there, heavier tyres etc for nastier courses drive the weights up a fair old bit. Even Manuel Ducci's Mojo HDR came in at just over 30lbs in Tolfa. Much lighter and you start compromising longevity I'd say.
My Mojo 160 hd in medium comes in at exactly 291b with vaults and reverb
industry nine enduro wheels tubeless, xt 2 x10 xt cranks, sixc bars,monarch rtc plus shock
i will post pics over the weekend
Posted : 15/11/2013 2:58 pm
I reckon the average weight will be between 29 and 32lb depending on the frame and build. It seems a lot of the EWS riders go for longer travel heavier equipment compared to some of the super light race machines we see on here but then they are limited to what their sponsors supply and can't risk a mechanical over the race weekend as replacement parts incur a time penalty.
My Alpine is 34lb but I have made no attempt to lighten it as I'm skint and saving for a house. In fact I made it heavier than normal by adding a dropper post (although I would love to lighten it up a bit next year). The Missus' Covert is about 32lb with tubeless tyres and a reverb.
I'm sure new wheels and carbon bits could make it lighter but I don't have the time or the money.
Tom Kp
Posted : 15/11/2013 3:29 pm
Pretty much bang on 31lbs - Rumblefish Pro 21" in 'as it came out the shop spec' plus DMVR Vaults.
Posted : 15/11/2013 3:59 pm
I must have dodgy scales or something!
... 'cos my 20" Five comes in at about 34-35lbs
Flow EX, tubeless, Minions DP rear/SP front
44RC3ti fork
CCDB coil
Mainly XT kit
2x9 with a DRS chain device
Reverb & std Bel-air
V-one bars and stem.
Nanos
Posted : 15/11/2013 4:03 pm
Another Mojo 140 here, Rev solo airs, Reverb, 2x9, XT brakes & hope discs.
DT Swiss 5.1 on Hope and High rollers. carbon bars & very light stem.
snicks under 30lb.
I'd have to spend a LOT more to drop a couple of pounds, I'm not sure about a lot of people's scales, not a lot of frames are lighter than a Mojo
Posted : 15/11/2013 4:16 pm
 LoCo
I swear the Remedy is made of coke cans (very very thin walls) 😉 few carbon guards dotted about on the frame for rock strikes, will re weigh in a bit when back together ready for the weekends trip 😀
Posted : 15/11/2013 4:20 pm
 LoCo
Current spec. 32 1/2 lbs.
Now has Pikes, hans dampf front, bonty xr3 team ed. back. steel bolts to replace a few of the cheesy ali ones, powa guard and pig iron 400m post while waiting for new nice one and the steel spring too. shock has just been shortened to a 183mm eye to eye and valved, ported and feels rather nice 😀 bit heavy now though 😉 The nics that were on there before weren't tough enough though as kept puncturing.
[url= http://farm8.staticflickr.com/7291/10871466114_d5e23a6e70.jp g" target="_blank">http://farm8.staticflickr.com/7291/10871466114_d5e23a6e70.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/55204994@N03/10871466114/ ]photo 2[/url] by [url= http://www.flickr.com/people/55204994@N03/ ]Loco Tuning[/url], on Flickr
[url= http://farm8.staticflickr.com/7310/10871375736_05c26afb69.jp g" target="_blank">http://farm8.staticflickr.com/7310/10871375736_05c26afb69.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/55204994@N03/10871375736/ ]photo 1[/url] by [url= http://www.flickr.com/people/55204994@N03/ ]Loco Tuning[/url], on Flickr
Posted : 15/11/2013 5:01 pm
I just stuck a der baron on the front of mine so it weighs approximately as much as my car, 32lb-ish I reckon.
Posted : 15/11/2013 5:57 pm
My 20" Five comes in at 30.6 lb on the bathroom scales. That's set up like this.
Posted : 15/11/2013 6:09 pm
You had those bathroom scales calibrated recently roverpig? 😉
Posted : 15/11/2013 6:16 pm
