assos mille info re...
[Closed] assos mille info required
[#2966320]
going to pull the trigger on a pair of these, they come in long and short version, can anyone tell me the leg length of the short/normal pair asi cannot seem to find it anywhere
ta
Posted : 20/07/2011 7:00 pm
 mrmo
on the Assos site is says 4cm longer for the long ones. The leg length does vary with size.
Posted : 20/07/2011 7:16 pm
and they come up quite short to start with though compared with other roadie makes though i notice this more as i'm 6' 6" !
i went for the 3/4 knicker versions (F1 uno T Knicker) almost like shorts on me!
as an aside v comfy
Posted : 20/07/2011 7:24 pm
they are a bit shorter than some brands - not sean yates short though, more like about a cm shorter than my moa/nalini ones...so i think the long version would be too long for me, but it depends on your body size
Posted : 20/07/2011 7:41 pm
dont get short,normal ones are short, short ones will look like hot pants.
superb shorts
Posted : 20/07/2011 7:48 pm
5ft 7 here with 31 inseam, dont really want to look like an extra from YMCA so may opt of the long version....
Posted : 20/07/2011 9:21 pm
oh, when i say 'short' version, i mean the normal ones
It depends where you are on the sizing chart - i was about 2 cm shorter than where the recommended large range began but they fitted me better better than the medium. However if i had the long leg version of the large then the leg would i suspect be too long, whereas if i had the long leg version of the medium it would be ok.
Posted : 20/07/2011 9:32 pm
