ASR5 and 140mm fork
[Closed] ASR5 and 140mm fork
[#6399640]
Currently running my ASR5 with 130mm forks, they are spaced down from 140mm. Considering running them at 140mm. Should be ok for the descents, but I have concerns about climbing.
Any ASR5 owners running 140mm care to share? Ta
Posted : 10/08/2014 4:03 pm
No probs with climbing for me with that setup, although I've always had 140mm so can't offer any comparison with 130mm. That may or may not be of any help at all.
Posted : 10/08/2014 4:40 pm
 Kit
Have mine at 140mm and it can be a little difficult to keep down on steep stuff, but then I have a few spacers under the stem too, and I'm out of practice. Realistically, is 10mm going to make much difference?
Posted : 10/08/2014 4:45 pm
I use it at 140mm (Revelations) and it's a climbing machine. Well, I think it is but I haven't spent too long at 130mm for a good comparison.
Posted : 10/08/2014 5:20 pm
Ran mine at 140mm no issue climbing at all, but same as muzzle never ran it with any less. Such a fun bike.
Posted : 10/08/2014 7:09 pm
went from 130 to 140, it is a bit lighter on the front at 140 and when I put the bigger forks on I was sure I preferred it at 130, but now I'm happy with it.
Posted : 10/08/2014 8:02 pm
Ive got a set of talas that i usually wind down to 120 when im climbing.. As kit says its a bit light on steep techy stuff at 140.. 🙂
Posted : 10/08/2014 8:05 pm
Ta for the replies, think 140 seems acceptable, just will need to be aware that steep climbs may be a bit more "interesting".
Posted : 12/08/2014 11:55 am
Yep fine here with 140mm. Crack on!
Posted : 12/08/2014 9:10 pm
 Leku
started with spaced down 130mm revs. Then had them unspaced to full 140mm for alps trips. They have now stayed like that for over a year. Descents a bit better, climbs just as well.
Posted : 12/08/2014 10:20 pm
 P20
I ran mine at 140mm. Brilliant fun
Posted : 13/08/2014 6:18 am
