Ashima Rotors - any...
[Closed] Ashima Rotors - any good?
[#5886128]
as per title. they are a bargain option. Would you use them with xt or zee brakes?
Posted : 23/01/2014 10:44 pm
Ive used ashima airotors with hope mini monos and found there was too much judder from the front brake (almost like an ABS feel). I now use shimano xt rotors and find them much better.
Posted : 23/01/2014 10:50 pm
 br
Very light and work ok with Hope x2's - but, you need to be aware they are very light.
Posted : 23/01/2014 10:52 pm
Ime They're Prone to warping and rip pads apart.
Have they decided which way they should be run yet?
Posted : 23/01/2014 11:05 pm
I like them because they're light. They do cause judder braking from some speeds or depending how hard.
However, I've been using them for 5 years and can't be bothered to change them, so I obviously don't find the judder that bad!
Posted : 23/01/2014 11:12 pm
 dobo
i use them on the xc bike and think they are very good paired with my xt brakes.
they make a bit more noise than my other rotors so may indicate higher wear rate on the pads but my xt pads seem to last ages.
I have them with slx bakes. No judder. Very noisy.
Posted : 23/01/2014 11:24 pm
