27.2 model specifically, as it stands the actuator thingy is positioned to the front left of the post but I’d like to change its static position like I recall was possible on the KS Lev models by loosening and rotating the head.
The head is fixed on the Ascend though, but I’m wondering if the collar can be loosened or something similar, anyone know?
Someone on here might know but in the mean time I would put a post up on crc asking that too.👍
I’d also like to know this so bookmarked.
Also, I've read several posts regarding adjusting the air pressure on an Ascend post - but I can't find any instruction/images online as to how this is done.
I'm assuming theres a valve under the 3mm hex bolt that resides under the saddle clamp - but before I go shooting myself in the eye with 250psi, is it safe to undo this bolt?
If it's anything like the KS lev (probably is) then the actuator can't be moved but the saddle mount can be rotated which achieves the same thing.
EDIT - Must read OP properly next time. Doh
Come on hive mind, this is the longest I’ve ever waited on STW for an answer.
Is this like some sort of SingleTrackwhack?
They’ve sold a million of these things, were are the users?
I still reckon crc might be your best bet on this one buddy. Takes a couple of days for the question to go live though.
I suspect there are very free people that have investigated this, even amongst owners perhaps?
