Arghh! Just fubarre...
[Closed] Arghh! Just fubarred my Maxle
[#3600811]
Just went to undo the Maxle Lite on my Revelations. Tried to unscrew the lever but it wouldn't budge so used a bit more force and managed to snap of the edge of the collar that the lever sits in when you're unscrewing. So now I have a stuck Maxle lever and nothing for it to push against to try to unscrew it 👿
Any suggestion on how to get the Maxle undone??!
Posted : 23/01/2012 9:29 pm
File a square edge into it further round the collar?
Posted : 23/01/2012 9:31 pm
Good suggestion sambob, will try that one out
Posted : 23/01/2012 9:35 pm
It happened to my mates the other month after some tools in his storage fell on the bike. Managed to (can't remember exactly) cut/file a smallish new recess in the collar so the maxle lever goes against this to undo.
A bit Heath Robinson but it was just before a ride and an emergency!
HTH?
Posted : 23/01/2012 9:36 pm
Sambob beat me to it!
Posted : 23/01/2012 9:38 pm
Did exactly the same. as said above file a square edge
Probably a bit late now, but make sure you grease that Maxle well!
Posted : 23/01/2012 9:43 pm
Thanks for the suggestions. Remembered I bought a Dremel a few months back, so filed back the jagged edge to a reasonable square edge as suggested and that was enough to undo it.
Pheww...had a bit of a panic on then for a moment! Will give it a good grease to make sure it's not so bad next time. Lesson learnt 🙂
Posted : 23/01/2012 10:13 pm
