argh me'julies...
[Closed] argh me'julies are leaking!
[#2001412]
my magura julies are leaking out of the dot of the i in the text 'oil' on the reservoir
whats that all about?
Posted : 17/09/2010 8:52 pm
can anyone give me a clue?
Posted : 17/09/2010 9:34 pm
Nothing to worry about, have you squeezed the lever whilst upside down or pushed the pads/pistons back in a long way when doing anything to them? If the levers feel soft they may need a bleed/top up in the reservoir.
Posted : 17/09/2010 10:08 pm
Usually just excess fluid trapped above the diaphragm being expelled, not normally anything to worry about unless it's continuous, in which case it's likely to be a punctured diaphragm, cheap and easy to replace.
Posted : 17/09/2010 10:14 pm
what are these things like to bleed?
Posted : 17/09/2010 10:16 pm
Pretty easy, just follow the instructions you get with the bleed kit, no voodoo magic required.
Posted : 17/09/2010 10:19 pm
ah ok. just had reservoir cap off (to top up) so prop just excess fluid.
will get bleed kit asap - can i just get the nipple attachments from somewhere?
Posted : 17/09/2010 10:39 pm
If no one else gets round to it, i'll think of an Ali G joke later.
Actually stuff it, everythings there, do it yourselves 🙂
Posted : 17/09/2010 10:40 pm
