Are brake mount ada...
[Closed] Are brake mount adaptors universal, any brand fits any brake?
 SiB
[#5466607]
In particular would a shimano adaptor be ok for formula brakes? Works on the back brake (shimano adaptor IS for formula PM brakes)so I'm assuming OK for front too, pm to pm?
Posted : 29/08/2013 3:11 pm
should be fine, I've done loads of different combo's although I have found I've needed to look at bolt lengths carefully between brands to make sure they don't bottom out in the fork or hit rotors etc if I do try and mix and match.
Posted : 29/08/2013 3:13 pm
Mostly yes. Sometimes a calliper may big a big large in one dimension that means it will foul on the adaptor. Normally sort this with a file though.
Posted : 29/08/2013 3:14 pm
 SiB
Thanks
I'll try the cheapo shimano ones first then the formulas if no joy
Posted : 29/08/2013 3:24 pm
avid ones normally need the stupid conical washers.
Not had any problem substituting hope for shimano and vice versa
Posted : 29/08/2013 3:50 pm
Had to file 5mm off a Hayes one to stop it fouling on the rotor. No idea what sort of bike/hub it was designed for, but an hour with the file did sort it.
Posted : 29/08/2013 3:55 pm
 MSP
Mostly yes, but some adapt the angle slightly differently between the rotor and calliper, I had one combo which left a corner of the pad outside the braking surface, can't remember which combo it was. But I do tend to try and use the correct adaptors these days (if I was buying a new adaptor). If I was using an adaptor out of the spares bin, I would check the pads after a few weeks to check nothing untoward was happening.
richmtb - Member
The spacing for tri-align washers is built into the caliper, not the adaptor. Avid adaptors are interchangable with shimano/formula/hope etc
Posted : 29/08/2013 4:16 pm
