are all front derai...
[Closed] are all front derailleurs the same thing?
[#7806784]
I need to replace an old 3x7 front derailleur, can i use a 3x10 onein it's place?
can be had for not very much money, and it kind of future proofs things... i'd be using the old 3x7 shifter.
or do i buy a 3x7 specific derailleur?
Posted : 04/05/2016 12:45 am
best to get one for the right size chainrins.
A shimano 3x10 might be designed for 24-32-42 so is slightly different to the older 3x9 22-32-44. It will work but might not be quite as crisp.
Also need to check the pull ratio but I do know that shimano 9 and 10 speed are the same.
Posted : 04/05/2016 1:14 am
I've used a 9 speed front mech for a 3x8 setup. It worked fine. But I have read that each size is designed for the relevant chain width.
Posted : 04/05/2016 3:36 pm
7 and 8 speed chains were the same width, but as mentioned above,will work best if matched to the right chainring profile.
same with 9 speed.
however, in practice you could use a 9 speed with a 7 speed chain without too much hassle, maybe have to cope with a little chain rub on the extremes of chain line (top or bottom of the cassette).
Posted : 04/05/2016 3:41 pm
Cool, thanks all
Posted : 04/05/2016 4:11 pm
Don't forget to check if it's top or bottom pull and the mounting type.
Cable routing can also be a PITA sometimes, but you usually only find that out once it's bolted to the bike!
Posted : 04/05/2016 4:52 pm
